  Muied Lumens Frequencies
Living VCO Troubleshooting
Page 1 of 1 [8 Posts]
bennethos
PostPosted: Tue Feb 09, 2010 3:38 pm    Post subject: Living VCO Troubleshooting Reply with quote  Mark this post and the followings unread
Does someone have an overview of the voltages for the tl072 pin layout without an ic ? or a reference sheet which voltages should be get where ?
for the TL072 :
VCO 2 :
6&5 -0.34v with ic , wihtout : +9.2v
2&3 : with ic : 0.32v , (shouldn't this be 0 ?)
8&0 : +14.63 without ic
4&0 : -14.63 without ic
VCO3 :
6&5 with TL072 in socket : 0.2v , without ic 8.98v
2&3 0V
8&0 without ic : 15.6v ( this looks like it's getting too much juice ?, this happens to be the only vco that's almost completely working, except for the bump when the sawtooth ramp starts. see pictures above)
4&0 without ic -14.07v
help would be appreciated, been debugging 4hours, it's fun I'm learning more about reading schematics & electronics :p .
Danno Gee Ray
PostPosted: Tue Feb 09, 2010 4:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here is the data sheet for the TL072.
tl072a.pdf
 Filename:  tl072a.pdf
 Filesize:  1.08 MB
 Downloaded:  207 Time(s)
bennethos
PostPosted: Wed Feb 10, 2010 12:23 am    Post subject: Reply with quote  Mark this post and the followings unread
I think I didn't made myself clear, I want to compare my measurements I posted vs measurements of someone's vco that works.
I know remote troubleshooting is hell, but what *can* I post so you can help me out ?
PostPosted: Wed Feb 10, 2010 1:40 am    Post subject: Reply with quote  Mark this post and the followings unread
I think some reference to which circuit you're talking about might help. Wink
bennethos
PostPosted: Wed Feb 10, 2010 2:26 am    Post subject: Reply with quote  Mark this post and the followings unread
Hmm I thought I was in the living vco section when I posted. well that's the circuit anyways Smile
jhaible
PostPosted: Wed Feb 10, 2010 11:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
If the supply voltages are about right (+15V at pin 8 and -15V at pin 4), plug these chips *in*. Voltages without these ICs don't make much sense.
If you burn a TL072, you burnt 50 cents.
Strange that you have *different* supply voltages on different pins. Something fishy here - there should be no voltage drop to speak of, across the ferrite beads.
JH.
bennethos
PostPosted: Thu Feb 11, 2010 12:36 am    Post subject: JH living vco troubleshooting Reply with quote  Mark this post and the followings unread
Hi Juergen,
Thank you for your time.
I have +15v & -15v on vco1 & vco3 . VCO2 gives +14.8v & -14.9.
If I put in the TL072's my sawtooth waveform has a dip when it starts (vco1 & vco3, vco2 is not working at all but I'm focussing on 1 & 3 atm) (see pictures I posted from oscilloscope).
VCO 1 has a second problem, when I up my frequency with the 10 turn after 3/4 the waveform rises flattens like a trapezium and drops. I think there's something wrong with the comparator not sending the reset impulse in time to the npn transistor or the input voltage of my tl072 on pin 6 causing problems with the GAIN calculation. It's all a bit new to me but I'm learning fast and it's exciting Smile
Could you tell me the voltage I should get on pin 6 & 7 of the TL072 please ? (vco 1 has -0.12v on pin 6, vco 3 0.21v with the 10 turn dial @ highest freq setting).
Other question, to make troubleshooting more easier (fixing my saw) I wanted to isolate the circuit by desoldering R27 1K resistor & removing the CA3086, is that OK or has it impact on creation of my saw ?
I will try to measure over the ferrite beads to see if I have a drop... One thing I noticed though, I followed Dave Brown's BOM and put in 10uF electrolytics near the Ferrite instead of 22uF...
thx
Benjamin
bennethos
PostPosted: Tue Feb 16, 2010 2:06 am    Post subject: Reply with quote  Mark this post and the followings unread
I solved my problem yesterday evening, as Juergen said "it's a silly problem most of the time" and he was right.
I actually inserted 1 wrong capacitor, the one between the base of the transistor and input of the comparator.
My saw waveform had a dip when it started and when my 10 turn was fully open (no resistance) I had a half trapezium :p .
on vco 2 pin 2 of the TL072 made no contact to anything, made a little bridge and that solved it as well Smile
can't wait to test those *beasts* Smile
