[slightly OT] math behind sine2 shape osc
Page 1 of 1 [8 Posts]
triptonizer
PostPosted: Fri Oct 29, 2004 4:57 am    Post subject: [slightly OT] math behind sine2 shape osc Reply with quote  Mark this post and the followings unread
Does anyone happen know the math behind this? Like you can substract 2 saws (same pitch and amp, the one syncing the other), and by modulating the second one's phase offset you create your own pulse pwm. All I know is that with shape = 100% it looks a bit like the bipolar version of a rectified sine, but I don't know how to get to the intermediate shapes. It's really for something I'm building in Reaktor; Reaktor has a similar Parabol pwm module, but it doesn't have sync and I need one that can be synched. I suppose I could get there myself by trial and error, but I'd prefer a takeway solution - don't feel much like cooking tonight Smile
Audio files: 218
G2 patch files: 319
PostPosted: Fri Oct 29, 2004 5:44 am    Post subject: Reply with quote  Mark this post and the followings unread
What I would try to do is make a sawtooth that can be made non linear. After that a table lookup or some simple math. That way the symetry of any waveform could be modulated by modulating the non linearity of the saw.
Just an idea,
Jan.
triptonizer
PostPosted: Fri Oct 29, 2004 2:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nice idea, thx Jan. But I'm afraid lookup tables will cause tons of aliasing... I'll give it a try though. Incidently, I asked this because I spent a couple of hours with an EMS Synthi100 yesterday at the university here (Ipem). Osc 1-6 (in total there are 12 oscillators!) are syncable (through the patchboard) and each osc has two outputs, one of which is 'SIne with Shape Control'. Hence my sudden interest in the matter Smile
ian-s
Audio files: 42
G2 patch files: 625
PostPosted: Fri Oct 29, 2004 3:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm interested as well, did you patch it into the scope to see what the intermediate wave looks like?
triptonizer
PostPosted: Fri Oct 29, 2004 4:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
yeah, and it's also described in the original manual: they look exactly like the Sine2 waveform on the G2's Shape Osc A, except that they have the full shape range (0...100%), so you get a sine with shape control in the middle position, turning the knob to the left is the same as moving the shape knob towards 100% on the G2 module, turn it to the right and you get the same output but with inverse polarity.
Rob
G2 patch files: 109
PostPosted: Sat Oct 30, 2004 10:38 am    Post subject: Reply with quote  Mark this post and the followings unread
There is a big difference between the G2 shape osc and how that distorted sine wave is made on the EMS, on the G2 the shape is distorted in the horizontal direction by means of a FM-like technique, while on the EMS the sine is created by distortion in the vertical direction, which basically is AM-like.
According to the EMS schematics a triangular wave is put into a triangle to sine converter, which uses diode devices to 'softly clip the top and bottom' of the triangle. The sine waveshaping distortion is made by adding an offset value to the triangle wave before it goes into the triangle to sine converter, forcing the result to be asymmetric.
The example patch is my solution.
Drawback is that this solution only works with a positive shape control signal, while on the EMS the control signal can be both positive and negative. In practise there not really an audible difference, so this solution is fine enough for me.
There is some extra circuitry to keep the signal level ok and prevent the waveform to shift towards the clipping headroom of the G2 outputs.
SynthiSineOsc.pch2
Emulation of the sine osc waveshaping on the EMS Synthi.
 Filename:  SynthiSineOsc.pch2
 Filesize:  1.13 KB
 Downloaded:  1080 Time(s)
ian-s
Audio files: 42
G2 patch files: 625
PostPosted: Sat Oct 30, 2004 12:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Rob, works very well.
And thanks Triptonizer, this wave sounds quite interesting when synced, specialy when you modulate the shape as well.
Is that a modified Synthi100 or do they all have sync? The VCS3 and Synthi-A need mods for sync and VC shape.
I hear Daniel Miller rescued a Synthi100 from a rubbish skip, lucky bastard!
triptonizer
PostPosted: Sat Oct 30, 2004 2:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
wow thx rob, I'll dig into it tomorrow but at first glance I think this would be pretty easy to emulate in Reaktor, which was my original purpose.
Do you by any chance have a similar solution for the syncable saw/tri shape osc in the Synthi? I only have the users manual here, no schematics.
@g2ian: it's not a modded Synthi100, all oscillators are syncable but you need to patch the sync source on the patchboard, nothing hardwired.
btw I heard Aphex Twin recently bought a Synthi100 on eBay Very Happy
