Repeatpeak
Joined: Dec 25, 2003 Posts: 46 Location: Boston, MA, USA
Posted: Sun Oct 31, 2004 11:16 am Post subject:
NM G1: Control signal question |
I have a question regarding the flow of control signals in the Nord Modular classic/G1. What I would like to achieve is a patch that allows me to control the speed of a note sequencer via the speed of an LFO and then 'switch' over to have the same note sequencer's speed controlled via midi clock. I guess it would be easy to just have two instances of an identical note sequencer module, one controlled via LFO, the other controlled via midi clock, connected to two duplicates of an OSC and then control the audio(!) mix between the two. But I was wondering if there is a way to actually mix or control the 'balance' of the stream of two control signals (in this case LFO and midi clock). Another solution could be if the NM would allow to simply switch back and forth between two incoming control signal streams.
Is there any way to implement something like this on the classic NM?
Thanks for help!
Philip
www.repeatpeak.com |
Roland Kuit
Joined: Sep 29, 2003 Posts: 991 Location: The Hague, The Netherlands
G2 patch files: 124
Repeatpeak
Posted: Mon Nov 01, 2004 6:26 am Post subject:
Thanks, Roland! I can't believe the audio modules can actually process control signals - Very cool! I guess it shows that I'm just starting out with this synth
Thanks for the helpful patch!
Philip
Roland Kuit
G2 patch files: 124
Posted: Mon Nov 01, 2004 8:47 am Post subject:
control sig question |
u'r welcome. If you are a Nord Modular user, don't forget to read the Tips&tricks pages at the Clavia website. Rob Hordijk did some very good stuff there. I did a few workshops aswell like a programming Techno, dr&bass, house workshop. For part two of the last one you need to contact me privatly. _________________ Roland Kuit
http://rolandkuit.com/ |
Repeatpeak
Posted: Mon Nov 01, 2004 9:59 am Post subject:
So much stuff to read for this synth
Thanks for reminding me of those tutorials!
BTW, the patches you have on your site are killer - Love the physical modelling stuff and have actually used one of your weird textural patches in some recent spiral7 sessions! Is that illegal?
Thanks,
Philip
www.repeatpeak.com
www.spiral7.com |
Roland Kuit
G2 patch files: 124
Posted: Mon Nov 01, 2004 10:27 am Post subject:
contol |
It's not ilegal because at the bottom of the mail list it says:
Patches sent to the Nord-Modular mailing list may not be redistributed
without the express consent of the author/creator.
But i think this has to be added: performing those patches or use them for cd recordings you have to have permission of the author of that patch. I got numerous mail from people that used my pch's for recordings, without mentioning where the pch came from and that pissed me off a lot. It isn't for the money but a thanx was in order by mentioning it on the cover or something. Other people and i spend ours a day without pay to get where we are now. So that's my point of view in this matter. And i'm still very grateful to a lot of people on the list that inspires me to explore.
(most of you guy's). So,........... that's out of my mouth!!!!!!!!!!!!! _________________ Roland Kuit
Repeatpeak
Posted: Mon Nov 01, 2004 11:51 am Post subject:
Great! I will definitely ask you if one of your patches will be used in our music/performances and will gladly mention your name on a CD.
It's great that people like you offer such high quality patches for download - As I said, very impressive sounds!
And thanks again for your help with the lfo/clock thingie!
Thanks,
Philip
www.repeatpeak.com
www.spiral7.com |
Roland Kuit
G2 patch files: 124
Posted: Mon Nov 01, 2004 1:57 pm Post subject:
control |
thanks a lot! and it's i repeat not about money. If i post a pch it's free to use, but with certain ethics. So you're welcome to use the stuff. _________________ Roland Kuit
