High or Last note priority in NM G1 patch - can it be done?
Page 1 of 1 [2 Posts]
Hopeless
PostPosted: Sat Feb 20, 2010 10:51 am    Post subject: High or Last note priority in NM G1 patch - can it be done? Reply with quote  Mark this post and the followings unread
Hello.
Desperation- (or is it despair?) is-me.
Try as i may i've so far miserably failed in constructing a (monophonic) patch with high- (or for that matter, low-) note priority, such as i could play it the way i would on, say, a good old trusty MS-20.
Logically i cannot be alone in the known universe as far as this is concerned. If at all possible, is there a solution to this problem?
I am aware of the fact the G1 as such does not sport anything but last-note priority but i was hoping one could construct the functionality desired with clever patching.
If this is the case i would be a very happy and eternally thankful camper indeed. Very Happy
If not, that is if it has been proven impossible, i would be very interested in said proof, sad as it may be.
Humbly, Hopeless (new user)
Top Top
PostPosted: Thu Apr 01, 2010 11:07 am    Post subject: Reply with quote  Mark this post and the followings unread
Could the compare AB module be used for this (in the logic section)? I can't think of exactly how off hand, but it might give you a start.
There has to be some way to do it. There is always some way to do it.
