Controlling beat tempo with mod wheel
Page 1 of 1 [3 Posts]
AngusHastie
PostPosted: Fri Nov 05, 2004 12:28 pm    Post subject: Controlling beat tempo with mod wheel Reply with quote  Mark this post and the followings unread
Simple question:
What's the best way of controlling the tempo of a beat generated by something like the drum synth OSC module with the mod wheel over a definable range? Want to use it for the intro to a song where the beat comes in and is then gradually brought up to tempo with the mod wheel (which also morphs other controllers at the same time). I'm trying to do it with a LFO hooked up to the trip input, but I seem to get multiple beats rather than just one steady beat.
Angus
PostPosted: Fri Nov 05, 2004 1:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
Try using a master clock -> sequencer, then use a morph to control the tempo knob on the master clock. The morph allows you to set the "range" you want as well.
AngusHastie
PostPosted: Sun Nov 07, 2004 7:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
Of course! Thanks.
