How to invert an LFO?
Page 1 of 1 [7 Posts]
LektroiD
PostPosted: Tue Mar 16, 2010 6:53 pm    Post subject: How to invert an LFO? Reply with quote  Mark this post and the followings unread
I'm trying to invert the polarity of an LFO. ie when the LFO is at its peak, the inverter outputs the trough, and so on... I have tried the inverter set either to standard, or inverse bipolar, but it outputs the same signal (same polarity) either way. Any ideas?
I hope I manage to get my intention across here via text. I have included an example, as you will see, I've used the left channel for one oscillator (non inverted LFO) and right channel for the inverted LFO.
Any help would be much appreciated Smile
Inverter .pch2
 Filename:  Inverter .pch2
 Filesize:  1.1 KB
 Downloaded:  400 Time(s)
My tunes available here
(check out the new Electro-Funk LP)
ian-s
Audio files: 42
G2 patch files: 584
PostPosted: Tue Mar 16, 2010 8:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
The symmetry of the wave modulation is confusing the issue. The pulse wave sounds the same no matter if it is made thinner or fatter. If you move both sets of wave shape and mod amount to the middle position, you should hear the effect you are after.
jamos
G2 patch files: 35
PostPosted: Tue Mar 16, 2010 8:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
The Level Convertor is your friend, here.
LektroiD
PostPosted: Tue Mar 16, 2010 8:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
It's not being very friendly with me, as you can hear for yourself!
ian-s
Audio files: 42
G2 patch files: 584
PostPosted: Tue Mar 16, 2010 8:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
To illustrate what I said. Also added two modules so you can see the inverter working. Very Happy
inverter2.pch2
see the inverter
 Filename:  inverter2.pch2
 Filesize:  1.82 KB
 Downloaded:  434 Time(s)
LektroiD
PostPosted: Tue Mar 16, 2010 8:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
That works! Many thanks Wink
LektroiD
PostPosted: Tue Mar 16, 2010 8:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
That illustrates it clearly, thanks again. thumb up
