 Forum index » Instruments and Equipment » iOS - iPad/Phone/Pod etc
MIDI I/O connector for iPhone
Post new topic   Reply to topic Moderators: mosc, v-un-v
Page 1 of 1 [3 Posts]
PostPosted: Thu Mar 18, 2010 10:30 am    Post subject: MIDI I/O connector for iPhone
Subject description: First and only of its kind- apparently.
MIDI Mobilizer – The only MIDI interface for iPhone and iPod touch
The only one of its kind, MIDI Mobilizer™ is the most portable MIDI system ever. Connect it to an Apple® iPhone® or iPod touch® to play, record, and store MIDI information any time, any place.
Go mobile.
Stop dragging around your computer – bring the most portable MIDI system ever. Connect MIDI Mobilizer to an iPhone or iPod touch for the fastest, lightest and easiest way to manage all your sounds, sequences and other MIDI data. No more waiting for your computer to start up, and no more lugging it to gigs.
• The most portable MIDI system ever
• Say goodbye to traveling with a computer
• The fastest, lightest and easiest way to manage all your MIDI data
Bring your backups.
Easily backup and transfer all your MIDI parameters from Line 6® gear and more, and rescue yourself from dreaded on-stage equipment failures. With MIDI Mobilizer you can import your MIDI sound data into replacement keyboards, and classic and modern MIDI equipment.
• The easiest way to safeguard your tones
• Never be without a backup
• Compatible with Line 6 gear, and classic and modern MIDI equipment
Capture musical ideas.
Quickly record MIDI any time inspiration strikes, and email your music as a Standard MIDI File (SMF). Open and edit the file within virtually all Mac® or PC-based digital audio workstations. Sending music to collaborators has never been simpler.
• Capture MIDI data quickly any time, any place
• Email music to collaborators
• Open/edit emailed music within virtually all digital audio workstations
MIDI Memo app.
Free at the Apple App StoreSM, MIDI Memo is simple MIDI software that records and plays any MIDI data. Its streamlined interface makes it easy for you to store, find and recall all your synth sounds, POD® patches, inspirations, and more.
• Free at the Apple App Store
• Easy to use
• Streamlined interface makes storing, finding and recalling MIDI data simple
Features
• MIDI Mobilizer is the only MIDI interface for Apple iPhone or iPod touch; The most portable MIDI system ever; The fastest, lightest and easiest way to manage your all your MIDI data
• Ideal for performing, recording, rehearsing, and inspiration capture
• MIDI Memo app (free at the Apple App Store) records and plays any MIDI data
• Stop dragging your computer to gigs; Never be without a backup; Email your music as a Standard MIDI File (SMF)
• Compatible with Line 6 gear, and classic and modern MIDI equipment; Includes two five-foot, five-pin Planet Waves® MIDI cables; Powered through iPhone or iPod touch – no batteries needed
So does this mean that the iPhone can also connect to a chromatic keyboard?
http://www.audiomidi.com/MIDI-Mobilizer-P12955.aspx
ACHTUNG!
Audio files: 107
PostPosted: Thu Mar 18, 2010 11:57 am    Post subject: Reply with quote  Mark this post and the followings unread
I think that you will only be able to use this with the one app they provide to record and playback midi. Still, it could be useful in some situations.
Audio files: 116
G2 patch files: 317
PostPosted: Thu Mar 18, 2010 1:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
IIRC the iPhone has a serial port connection available on it's extension connector, if that one can be set to the MIDI baudrate it would not take much more than a buffer and an opto coupler to provide the MIDI I/O. Not sure about how this would look from the API side but $99.99 seems a bit pricey to me.
ok .. there is some info out there about his, see for instance http://devdot.wikispaces.com/Iphone+Serial+Port+Tutorial
JuneSolstice2013
