Alexander
Joined: Apr 22, 2006 Posts: 374 Location: 's Hertogenbosch, NL
G2 patch files: 4
Posted: Mon Mar 29, 2010 5:45 am Post subject:
Rapman |
I got myself some casio rapmen! I already experimented and overclocking and glitching it is no problem.. and very very stable!
What i am trying to do right now is create an internal feedback loop, with a pot to control the amount and a switch between external and internal sound source.
Does anybody have any experience with this mod.. please help me out with how to take the output and get it back into the pitch shifter without using cables and a mixer!
Any help is very much appreciated. _________________ http://husc-sound.com |
alienmeatsack
electri-fire
G2 patch files: 4
Posted: Mon Mar 29, 2010 4:12 pm Post subject:
| alienmeatsack wrote: | | It can't be just as simple as connecting the output to the input right? Would you need protection in line as well for accidental backwards current? |
Backwards current? What's that? I think a pot would do. I've seen it done on youtube.
Or a microphone mounted near the speaker.
http://groups.yahoo.com/group/benders/message/13303
I got one waiting to be bent, might have a look someday. Hey,Alexander, if you come to Breda we can have a Rapman Bending Party. Beer etctera 's on me. |
alienmeatsack
Posted: Mon Mar 29, 2010 4:34 pm Post subject:
LOL. I don't know. I've just seen some talk about possibilities of the electricity going backwards. Ignore me. I'm a newb today
Is there a trick to bringing the output to the input? Do you just wire the positive to the positive? Do you also wire the ground to the ground?
Is there an easy way to introduce a small delay, maybe a cap? Any precautions like resistors and such that need to be added?
I'm interested in how it works, what tricks to use, etc.
BTW that Yahoo group link does not work for me. Says I have to be a member with no means to sign up. _________________ My Circuit Bending Site (Coming Soon)
My Circuit Bending Blog |
electri-fire
G2 patch files: 4
Posted: Mon Mar 29, 2010 4:59 pm Post subject:
Thu Mar 25, 2004 5:11 am "Bryn Truelove" posted on http://groups.yahoo.com/group/benders/
I've been poking around a Casio rapman
and found some bends that I'd like to share. Most of
them effect the beats. Haven't
found anything to effect the pitch. I don't think that it uses an
RC circuit for timing...
All the components on the circuit board are marked with numbers
(R32, C13, ect) so I'll give the number to be connected.
FB1 - R36 = overtone lead overtop of the beat
R16 - FB1 = loud good sound pitch can be changed by 10k pot or
chirping made with 0.02uf cap)
FB1 - emmiter of trans'r by R36 = complex tone lead created over beat
FB5 - a bunch of different places including the tops of electrolitic
capacitors = by far the best of the bunch. When in "rap" mode
with the beat playing quickly make a connection and it produces
random well timed glitched out loops or crashes out compleatly. Use
on/off sw. to reset.
FB4 - R12/R13/R14 (and a bunch of other places) = pretty much the
same as above but seems to make different sounding loops. Good to
do the above glitch first and then this one after to change it a bit.
Also there are two area's on the left and side of the board with
five or six parallel jumpers (wires). One group running up and down
and the other running side to side. I can't figure out how to
explain which wire is which, but... with a beat playing, poke around
in there, connecting one group to the other, until something good
happens. You should get an overtone that plays along with the
beat. This is also one of my fav's.
Last thing and maybe the best, /.../. The rapman has a builtin "voice effector" which
pitchshits your voice up or down (in octaves or fifths I think). I
bought one of the $2 mikes that they sell in dollar stores around
here and took out the small plastic cylinder that the diaphram is
mounted in and then hooked it up perminantly to the keyboard. The
first cool thing that you can do with this is hum into it like a
kazoo and it makes a wicked, very electronic sounding lead. Doesn't
sound anything like anything make by a mike. The second thing that
you can do with this little mike is hold it infront of the speaker
for some nasty sounds. It picks up whats playing and pitch shifts
it up or down. You can also control the feedback to the point that
you can actually play it. Put the mike close for three counts take
it away for one. /.../
(Disclaimer: shortened by electri-fire. If anyone objects to my copying/editting this post it will be deleted.) |
electri-fire
G2 patch files: 4
Posted: Mon Mar 29, 2010 5:15 pm Post subject:
| alienmeatsack wrote: | Is there a trick to bringing the output to the input? Do you just wire the positive to the positive? Do you also wire the ground to the ground?
Start with inserting a potentiometer between the (positive) in and output.
Suppose you wire it so turning clockwise reduces resistance, so you get more feedback (middle and right solderlug when looking from top side).
When feedback gets too much to your taste, set the pot to the amount of feedback you want at maximum, and measure the resistance between the middle and right lug.
Now insert a resistor of that value (or slightly higher) in series with the pot. This resistor can be inserted anywhere in the feedbackpath, at the circuitboard, at the pot, whatever.
There's no need to do something with the ground connection when feedbacking within one device.
Capacitors can be used, but work as a filter, not delay in the usual sense. |
Sam_Zen
Posted: Mon Mar 29, 2010 7:01 pm Post subject:
Some additions about feedback :
out - in :
It's always asking for trouble to directly wire some output of a device straight into its own input.
Always start with some component in between, pot or resistor.
Sometimes a feedback situation ends up very quickly in a very high frequency oscillation,
which can cause serious power consumption problems, like a CPU running at 100 %, so much current.
These HF signals can be often sufficiently dampened even only by the presence of a resistor,
which has also a capacitance on its own, so acts as a tiny filter too.
Ground :
If the connection is an internal one of the device, there's no need to connect the V- of the output plug to the V- of the input plug.
On the contrary, it could mean a "groundloop" in the system, causing a net-hum (50/60 Hz) on the line.
A caution : Not all outputs, like a headphone plug, have as 'minus' the common power ground V-.
Sometimes it has a "floating zero", which is not the same. _________________ 0.618033988 |
Sam_Zen
Posted: Mon Mar 29, 2010 8:08 pm Post subject:
I was curious about this Rapman, did a search and came upon :
http://www.synthmania.com/rapman.htm
Quite a lot of demo MP3 samples.They are mono, no problem.
But concerning timing, these samples are just sloppy crap.
Just choose a beat from the pattern section, having your player set in 'repeat' mode, knock the beat on the table,
and you'll see what I mean.
Is there some technical circuit available of the Rapman by the way? _________________ 0.618033988 |
Alexander
G2 patch files: 4
Posted: Tue Mar 30, 2010 12:20 am Post subject:
Great info! This helps. I searched for a technical schematic or service manual, but I still haven't found what I am looking for!
I'll open one up completely and take some pictures of the circuitboard, makes it easier to locate the bends!
Another thing I am trying, is replacing the pitchswitch with a pot, to have more options for shifting! Default is 1 or 2 oct down and up!
Great help, you guys rock as always!
@electri-fire I am in Breda soon for my sis' curfew evening, it's the 15th! Maybe we could meet and plan this beerbendfest!  _________________ http://husc-sound.com |
Alexander
G2 patch files: 4
alienmeatsack
Alexander
G2 patch files: 4
Posted: Thu Apr 01, 2010 1:01 pm Post subject:
I'm photographing the process, it wiill make a nice blog entry when I get done.. For now I'm going for a simple glitch crossfader option, internal feedback and magenta spraypaint!! I've got a few spare ones, to experiment further with!
Maybe i could control the pitch shifter by the pwm signal from my arduino! That would make my first casio with usb..  _________________ http://husc-sound.com |
alienmeatsack
telstarmagikistferrari
Joined: Jun 16, 2008 Posts: 275 Location: Indianapolis, Indiana
Audio files: 43
Posted: Thu Apr 01, 2010 11:40 pm Post subject:
| man those beats that dude sampled are R-R-R-RAW! also hilarious. His tickling of the ivory just pisses me off, but at least he left a bar or two on most of them before he comes in. Cool thread, can't wait to hear the bends. |
Alexander
G2 patch files: 4
Posted: Fri Apr 02, 2010 12:59 am Post subject:
NOTE:
- The numbering of components mentioned above by elctri-fire, is only on realistic versions, the casio has the values of the components, not the numbers! _________________ http://husc-sound.com |
Alexander
G2 patch files: 4
alienmeatsack
Alexander
G2 patch files: 4
Alexander
G2 patch files: 4
electri-fire
G2 patch files: 4
Posted: Tue Apr 06, 2010 5:19 am Post subject:
[quote="Alexander] it's bad to post pictures and no sound in a circuit bending forum [/quote]
Well, it's got a beauty paint job.
[quote="Alexander]here's a quick and dirty demo:[/quote]
Nice! And thanks for posting the pitch changer datasheet. Very interesting. For a moment I even considered to remove the chip from the Rapman and put it in a seperate little box. |
Alexander
G2 patch files: 4
Posted: Tue Apr 06, 2010 10:51 am Post subject:
Nice, thank you!!
I have been thinking about taking the ic out and doing something with the twelve stages of pitch shifting, but the ic doesn't have long legs and is (i think) impossible to remove, without damaging it..
It did give me new ideas for g2 patches!
This one was a lot of fun, I found my old Boss DS2 still works, so that one is next, but I'll try and follow up with more experiments with the pitch shifter!! _________________ http://husc-sound.com |
Sam_Zen
Posted: Thu Apr 08, 2010 8:51 pm Post subject:
nice demo ! _________________ 0.618033988 |
Joined: May 16, 2005 Posts: 8900 Location: Birmingham, England, UK
Posted: Fri Apr 09, 2010 12:35 pm Post subject:
| Alexander wrote: | | Nobody...? |
Fab mp3 demo!
I don't know what happened to my Rapman Perhaps I put it on eBay, and now I can't remember?  _________________ ACHTUNG!
Alexander
G2 patch files: 4
Posted: Sat Apr 10, 2010 3:10 am Post subject:
| Quote: | | Perhaps I put it on eBay, and now I can't remember? |
Maybe it ended up on the desk of a young dutch audiogeek?  _________________ http://husc-sound.com |
spam4life
Posted: Sat Apr 24, 2010 3:18 am Post subject:
great!!!!
can you do a "how-to" of the feedback mod? |
