Simple VCA with bonus S&H/Glide on one piece of stripboard
Page 2 of 2 [28 Posts]
Goto page: Previous 1, 2
nicolas3141
PostPosted: Sun Nov 04, 2012 5:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
To make it sample as quickly as possible, reduce R103 to 10k or even 4.7K (don't go any lower than 4.7k or you might blow up the 13700) and use a TL074 or similar for IC1d (R106/107/108 will not be necessary) which will then allow you to significantly reduce C101. A smaller C101 will reduce the hold time before you notice sag, but you could experiment with different values between 1n and 50n to find a good compromise. Those 3 changes will improve the high freq performance dramatically.
R103 --> 10k
IC1 --> TL074
C101 --> 10n (experiment a bit with this value and let us know what you find)
And of course make sure P101 is right round at the fastest setting possible.
Bogus Noise
PostPosted: Mon Nov 05, 2012 12:35 am    Post subject: Reply with quote  Mark this post and the followings unread
That's great advice, thanks Smile
I will test it out this week and report back. I already have a dual glide module and will be using this mostly as a sample and hold so shouldn't need to compromise too much, but I'll post up how things go regarding the glide response as well.
Circuit Bent Sonic Absurdity:
www.bogus-noise.co.uk
http://www.youtube.com/user/BogusNoise
Bogus Noise
PostPosted: Tue Nov 06, 2012 9:52 am    Post subject: Reply with quote  Mark this post and the followings unread
Well, have given it a bit of a test. 10k and 10nf capacitor works well at high sampling rates, but drifts quite a bit if there's say a second or so for each cycle. I changed to a 100nf, still drifts a bit. It's more noticable on higher voltages (both + and -), the closer it is to 0v the longer it holds. It's good enough for the moment but when I get a chance I'll experiment with some more values to try and get the performance at higher voltages to be a bit more stable.
I'm also thinking about about adding a gate to trigger circuit on the input, could be a handy extra!
emSynth
