MIDI Delays all Zone.
Page 1 of 1 [3 Posts]
wyleu
PostPosted: Sat Nov 13, 2004 12:15 pm    Post subject: MIDI Delays all Zone. Reply with quote  Mark this post and the followings unread
I find the present MIDI Zone module very limiting as it seems to have no mode that allows temporal modulation a'la delay lines.
some form of 'grey' input/output that is MIDI stream data that would allow MIDI type processing. Thus a particular zoned stream could be transposed' or 'delayed' or 'modulated'
The ability to produce control this way seems an interesting combination when a dear old G1 hangs off a G2. It also allows all MIDI processing to be handled at the G2's inputs and selectively passed through to the G1, thus presenting a sort of standardized Modular G1/G2 input at the G2 input socket.
Taz says:- 'My Sub My Rules'
Audio files: 107
PostPosted: Sun Nov 14, 2004 11:35 am    Post subject: Re: MIDI Delays all Zone. Reply with quote  Mark this post and the followings unread
wyleu wrote:
I find the present MIDI Zone module very limiting as it seems to have no mode that allows temporal modulation a'la delay lines..
You are right that the MIDI Zone is pretty limited. It's intended, I think, for a simple task of defining keyboard zones. For that task, it is pretty excellent.
If you want to do temporal modulation, use the MIDI receive and MIDI send modules. The Keyboard module can also be used and it more efficient if if you can get by with it. The MIDI Recieve and Keyboard modules make blue signals from the MIDI. You can use the S&H modules and the delay modules to do temporal modulation. You can do transposition with a simple mixer. You can use the note scaler, and any other module you can think for additional processing.
See my patch on the midi time quantizer http://electro-music.com/forum/topic-3742.html to get some idea on how to get started. You can do much more than this.
Midi processing is a great strength of the G2. I know of no synth that even comes close to having this capability.
Rob
G2 patch files: 109
PostPosted: Thu Nov 18, 2004 4:42 am    Post subject: Re: MIDI Delays all Zone. Reply with quote  Mark this post and the followings unread
[quote="mosc"]
Another example is at http://electro-music.com/forum/post-25190.html#25190
/Rob
Niio1
