 Forum index » Instruments and Equipment » Waldorf
Pulse Plus Wiring
Page 1 of 1 [5 Posts]
BobbyB
PostPosted: Tue May 04, 2010 3:27 pm    Post subject: Pulse Plus Wiring
Subject description: A wire is loose, anyone know where it goes?
A wire is loose inside from the CV Gate section. It's the 2nd wire in the series from the left. Anyone know where it goes?
Ashe37
PostPosted: Tue May 04, 2010 8:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
This is just a theory but look at this connection:
E-Mu e6400 Ultra -Ensoniq VFX & ESQm
Korg M3, EMX-1 , MS2000BR
Roland MKS-50, Juno 106 Alesis Micron
Waldorf Blofeld
jmejia
PostPosted: Mon Jun 21, 2010 5:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
That's exactly right - good guess Ashe37! I have my pulse+ open right now for a different issue - and I can confirm that your suggestion for that wire is correct. I'd take a pic if I had a camera - but your overlay on that pic is pretty clear. When it's in the correct place you'll have 3 vertical adjacent pads connected what look to be the 'shift' button connections
now.. anybody have a service manual?
Dougster
PostPosted: Tue Aug 23, 2011 11:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
I have a Pulse Plus, but a different wire was loose. I took a couple videos to document the attachment points, one of each set of wires.
The set of wires in this thread:
(Between the pictures in this thread and the video, that covers all the connections.)
and the other set of wires:
Once you start down the modular path, forever will it dominate your destiny!
Every DIY person should own a copy of Electronotes: http://electronotes.netfirms.com
Blue LEDs are evil.
jmejia
PostPosted: Wed Sep 26, 2012 12:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
This is an old topic - but one I came back to recently while repairing my pulse+ last night.
Unfortunately the image that clarifies that hanging wire is no longer hosted - but I figured it out from the thread, fixed my pulse+, and thought for completion/posterity/archival reasons I'd annotate that initial image and post it here - since this is a common problem that isn't documented anywhere else on the web. (That I've found.)
The videos in this thread are great, and the only wire missing from them is explained in my annotations here.
