Like An ARP
Unkie Al
PostPosted: Tue May 25, 2010 2:03 pm    Post subject: Like An ARP
Subject description: replace banana jax with slide faders
Hello from the nation's capital.
Maybe I just wasn't able to find it while I navigated around, but has anyone done a mod to Ray's "Ultimate" that uses pots (slide or otherwise) to route signals around to various modules, much in the manner of classic ARP synths?
For example, the sample and hold circuit feeding variable levels to Oscs, the filter, etc.; or the output of one VCO on a slider to add a little FM to the VCO next to it... you get the idea.
To pull this off, would it make sense to add the equivalent of a distribution amp (one input feeding a pile of isolated outputs)? Or is there enough signal present that all circuits would be happy and not cause other parts of the synth to 'sag'?
I've got a panel design banging around inside my head that I want to take on as a fall-winter project, but need to know if this has been done. Again, forgive me if this has been asked before, but I've not found anything.
Thanx all.
