 Forum index » Instruments and Equipment » Nord stage
How to activate string resonance on the Nord Stage EX
Page 1 of 1 [2 Posts]
daduk
PostPosted: Fri May 28, 2010 3:44 pm    Post subject: How to activate string resonance on the Nord Stage EX Reply with quote  Mark this post and the followings unread
Hi guys,
First post here.
I am a Clavia fanboy and own the Wave, a Nordlead 3 and the Nord Stage EX 88.
Can someone please tell me how I can activate the string resonance function. from what the manual says I can't get the expected results..
Thanks,
Daduk
Pabl
PostPosted: Mon May 31, 2010 4:51 am    Post subject: Reply with quote  Mark this post and the followings unread
It should be as easy as pressing the Clav EQ button, if I remember right. The screen will read String resonance on/off.
Be sure you're trying it on a sound that allows this function (not all pianos are suitable). In the piano library v4, you should check for those with XLR on their names. In the newest piano library v5, small files have the string resonance disabled. Also, if you want to load new sounds from this library, you have to update OS to 6.02
www.versusfive.com
www.myspace.com/versusfive
Niio1
