  bingsatellites Mostly Ambient
 Forum index » Clavia Nord Modular » G2 Performances - Noodles
Horribility
Audio files: 218
G2 patch files: 93
PostPosted: Fri Jun 11, 2010 9:21 am    Post subject: Horribility
Subject description: Noodle for the 24/7 event
Here's a noodle thing I did for the 24/7 event 7-13 june 2010.
It's actually seven single-slot noodles, each in its own slot. The eighth slot (the bottom of slot A) is used to switch between the other seven. You'll need an expansion to get them all going - if you don't have an expansion you could load the performance and just clear four of the slots.
I made the patch to play along with other stuff, only playing a single slot at a time. As it happens, lots of slots were active when I put it on wednesday morning (logging into the chat and telling jfox - awesome work at the controls by the way - that I had stuff running on my port), and the noodle spent the day gradually turning off stuff. It hadn't gotten around to playing single slots as intended until my workday was almost over. I think it worked pretty well anyway.
If you feel like trying the individual slot noodles out by themselves, I've marked the main volume controls with green colour. It works a bit differently for some of the noodles, but I think you'll figure it out.
/Stefan
horribility.prf2
 Filename:  horribility.prf2
 Filesize:  31.91 KB
 Downloaded:  447 Time(s)
emSynth
