new user and weirdo problems with my a6
Page 1 of 1 [6 Posts]
nellogentile
PostPosted: Sat Jul 03, 2010 10:25 am    Post subject:  new user and weirdo problems with my a6 Reply with quote  Mark this post and the followings unread
hi all,
i got an andromeda a6 since 2004 and it was working like a clockwork till 2 weeks ago.
Now i got a really strange problem i cant really identify.
i am describing it:
when i select a patch and i press keyboard the sound start really slowly
like if a super slow attack is on the patch, and both the osc are oscillating randomly detuning up and down costantly.
i think that the digital interface is working because i can change patch very fast. but the sounds they recally barely recalls to the one i know.
when i set it to monophonic and just turn on osc 1 or 2 it behaviours like a siren going up and down slowly. the key trigger (after the first one with the slow attack) seems normal but if i reset it to polyphonic each voice takes like 8 10 seconds to show up.
any idea of whats happening?
nellogentile
PostPosted: Sat Jul 03, 2010 1:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
any idea of a specialized service i can send it for repair?
in europe
Perfect Day
PostPosted: Sat Jul 03, 2010 1:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
Maybe try a hard reset , Sounds like youve got an LFO modulating the oscillators ? Is the mod Wheel up ? Do you have a delay before the attack in the envelope section , Maybe set the amp to norm 1 The lfo modulating the oscillators (If thats whats happening ) might be set to rise from bellow 0 and that may be trigering the amp to start ? Just some Ideas .Are all mods off in the oscillator section ?
Perfect Day
PostPosted: Sat Jul 03, 2010 1:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
You could have a read through the service manual , somebodys provided a link to the download on the forum , The power up options would be a good place to start if youve got your patches backed up or you dont mind losing them if you havent already tried . As far as service centers go , Alesis arent serviceing the A6 anymore . Theres a lot of stuff you can do yourself if you check out the service manual . If the second key press has a fast attack it sounds like youve got your amp set to analog so if you have a release on your mono patch the second key press will trigger your amp from the level it is at when you press the new key (not necasarilly 0)
nellogentile
PostPosted: Mon Jul 05, 2010 7:39 am    Post subject: Reply with quote  Mark this post and the followings unread
hey thanku for the answer,
i am going to get the service manual and check for some routine.
well no it doesnt liek a lfo modulating the oscillators because their pitch and volume is totally random and yes on the panel i turned off al modulations leading to them
Smile i am gona try this hardware reset thanku again
Perfect Day
PostPosted: Mon Jul 05, 2010 11:24 am    Post subject: Reply with quote  Mark this post and the followings unread
No bother . Let me know how u get on . Just in case you dont know all the power up modes are on page 269 of the reference manual
JuneSolstice2013
