Simple DIY dsPIC Project
Page 4 of 6 [148 Posts]
JovianPyx
Audio files: 190
PostPosted: Mon Oct 22, 2012 5:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
Code for ADC for 2 potentiometers (or CVs) is now working. I used DMA in one-shot mode to reduce both CPU time and RAM used. Only 2 words of RAM are needed, one for each pot value. ADC is working in ALTS mode. No interrupts are required. Each ADC cycle is initiated by a single BSET instruction. Because the DMA controller has registers for 2 channels, these can be set (for two pots) and never touched again. So almost magically, all one needs to do is issue a channel-enable (one BSET) and just wait for the result. If done in a pipelined manner, there is no need to poll any "done" bit (assuming the processing time is longer than it takes the ADC to finish it's work).
I find this a very powerful feature of the dsPIC to be able to use DMA in this manner since the hardware can be doing two things at the same time - crunching the ADC and doing whatever calculations need doing. Note that DMA in a dsPIC does not cycle steal from the CPU because it uses a second port to the SRAM.
This method can be coupled to the DAC interrupt timing and reduce total interrupt push/pop and peripheral maintenance code and associated overhead. Of course, with a bit more overhead more pots could be managed this way. My current project requires only 2.
Note that reading pots is a low intensity need in my synth.
Time flies like a banana.
corruptio optimi pessima
JovianPyx
Audio files: 190
PostPosted: Mon Oct 29, 2012 8:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
I've gotten a basic one string Karplus-Strong model to work which can be controlled by 2 pots, one for linear damping and one for low-pass filter Fc. It works quite well and proves the ADC, DAC and SPI code works. This uses a dsPIC running as MIDI controller and voice assigner connected to a dsPIC which runs as a voice engine.
PostPosted: Tue Oct 30, 2012 5:04 am    Post subject: Reply with quote  Mark this post and the followings unread
How does it sound? got a demo?
What is the next step - fine tuning the sound or adding polyphony?
JacobWatters.com
JovianPyx
Audio files: 190
PostPosted: Tue Oct 30, 2012 3:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here is a sample from the single delay line version. The first half or so was with 2x oversampling, so an octave higher, the second half used no oversampling. Some scales and notes with different settings. 2 pots, one for linear damping, the other is for the reflection filter - lowpass single pole. This is very early in development. One thing I hear is a prominent click in the start of the waveform at pluck time. This is most likely because I am using a simple rectangular pulse to excite the waveguide. I'm hoping that If I make the "pluck pulse" a trapezoid, it should improve.
PLEASE DON'T PUT THIS IN THE PLAYLIST, IT'S BORING.
dsPIC_one_string_harp.mp3
Single String Digital Karplus-Strong Model Using dsPIC33F
 Filename:  dsPIC_one_string_harp.mp3
 Filesize:  4.36 MB
 Downloaded:  431 Time(s)
Dan Lavin
Audio files: 21
PostPosted: Tue Oct 30, 2012 4:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
Scott, I think it's only boring if you don't hear the potential there. This is good work! I would agree on the initial pluck being a little digital/click sounding (like the whole thing isn't digital Wink)
Looking forward to further reports!
Synth DIY since 1977!
Audio files: 218
G2 patch files: 319
PostPosted: Wed Oct 31, 2012 3:54 am    Post subject: Reply with quote  Mark this post and the followings unread
Sounds like liftoff to me, great!
PostPosted: Wed Oct 31, 2012 5:30 am    Post subject: Reply with quote  Mark this post and the followings unread
Wow! That sounds awesome! Great work Scott Smile
JacobWatters.com
JovianPyx
Audio files: 190
PostPosted: Wed Oct 31, 2012 7:56 am    Post subject: Reply with quote  Mark this post and the followings unread
I tried 2 things to eliminate the pop at the start of the sound:
1) random fill - This did nothing to decrease the pop (which I suspected, but I wanted to try it to hear if the randomness would add randomized character to the timbre). Timbre sounded good.
2) Trapezoid excitation pulse. This worked wonders. Only 4 samples from zero to full scale was enough to eliminate the perception of a pop. Because I don't clear the delay line before excitation, the timbre is sufficiently different each time a string is plucked while it is still vibrating.
JovianPyx
Audio files: 190
PostPosted: Thu Nov 01, 2012 4:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
The dsPIC voice program is now 4 voice polyphonic.
I have included a demo in which I use a MIDI sequencer to play a repeating set of notes that span the range of the instrument. As the sequence plays (about 4 minutes), I noodle the 2 knobs (real pots) on the synth. One is the damping knob, the other is the filter knob. As you can hear, there is quite a range of timbre change available with just these 2 knobs. I can also change the exciter pulse length as a fraction of the waveguide length only as a matter of recompile at the moment. For the demo it was set to 1/4 wave which gives a good amount of energy for harmonics as well as a fundamental with good amplitude.
dsPIC_4_string_harp_demo_01.mp3
dsPIC 4 String Harp Demo
 Filename:  dsPIC_4_string_harp_demo_01.mp3
 Filesize:  3.76 MB
 Downloaded:  390 Time(s)
JovianPyx
Audio files: 190
PostPosted: Fri Nov 02, 2012 8:17 am    Post subject: Reply with quote  Mark this post and the followings unread
Instead of a trapezoid pluck pulse, using a single pole lowpass IIR filter and a rectangular pluck pulse to generate the pluck, I was able to eliminate many cycles of execution time. The actual voice generation code uses 296 clocks for four voices at 2x oversample. That means 592 for 8 voices. The total clock count available is 708, so more than 100 are available each sample time for "other stuff" such as dealing with incoming SPI messages, ADC values, pluck pulse start, etc. A 12 voice synth with 2 voice engines (and one more dsPIC for MIDI controller) is looking very possible now.
sneakthief
PostPosted: Fri Nov 02, 2012 8:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Keep up the good work, Scott.
I've been following your progress since the beginning and this really shaping up into a great project.
I'm fascinated by the thought of having tiny, discrete hardware synths that I can bring with me during my live performances (weight always being a limiting factor).
FWIW, that's even more voices than my Nord Micromodular can handle when modelling something like this - nice Smile
Sneak-Thief - raw electrofunk
JovianPyx
Audio files: 190
PostPosted: Fri Nov 02, 2012 8:56 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks sneakthief,
This has been quite a load of fun actually. The dsPIC is a very powerful chip. In fact, since writing my last post, I've reduced the clocks to 256 for 4 voices at 2x oversample. The DSP instructions allow quite a bit of parallelism where several different things are happening within the same clock period. Besides good, clever logic design, the two most important factors in reducing clock overhead are the DSP instructions and the addressing modes. I discovered that I had done addressing arithmetic with discrete add instructions when I could use an addressing mode that auto increments or adds two registers to get an address.
I also have plans to push some things that are being done by the voice engine into the MIDI controller which will lower the clock overhead even more.
And I'm still looking for more ways to reduce the overhead...
JovianPyx
Audio files: 190
PostPosted: Fri Nov 02, 2012 7:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here's another demo, same sequence, but with several improvements to the code.
dsPIC_4_string_harp_demo_02.mp3
 Filename:  dsPIC_4_string_harp_demo_02.mp3
 Filesize:  3.87 MB
 Downloaded:  412 Time(s)
sneakthief
PostPosted: Sat Nov 03, 2012 3:50 am    Post subject: Reply with quote  Mark this post and the followings unread
Will you be connecting a display?
What are your thoughts about using graphics displays with SPI, such as this:
http://www.ebay.com/itm/1-8-Serial-SPI-LCD-Module-MicroSD-Socket-ST7735R-For-Arduino-/160758311211?pt=LH_DefaultDomain_0&hash=item256df1292b
...or this:
http://www.ebay.com/itm/1-5-SPI-Parallel-TFT-Color-LCD-Module-Display-128X128-RGB-Y100-/261036873880?pt=LH_DefaultDomain_0&hash=item3cc7029898
Or perhaps a simple 16x2 I2C version:
http://www.ebay.com/itm/Serial-IIC-I2C-TWI-1602-162-16X2-Character-LCD-Module-Display-For-5v-Arduino-/300746445605?pt=LH_DefaultDomain_0&hash=item4605e29325
JovianPyx
Audio files: 190
PostPosted: Wed Nov 07, 2012 6:57 am    Post subject: Reply with quote  Mark this post and the followings unread
This particular synth needs no display since there is no patch memory. All of the timbre information comes from the 2 pots.
However, if I were to use a display (perhaps in another synth), I'd consider SPI since the dsPIC I'm using has 2 SPI channels and I use only one for interprocessor communication.
JovianPyx
Audio files: 190
PostPosted: Wed Nov 07, 2012 7:01 am    Post subject: Reply with quote  Mark this post and the followings unread
The second voice engine dsPIC has been added and wired up. It is currently running a data reliability test with SPI. The SPI (sent from the MIDI controller in master mode) now drives 2 devices and has run for more than 24 hours with no errors. The test sends 32 bit messages, the first 16 bits is a pseudorandom word from an LFSR. The second word is the inversion of the first word. The receiver inverts one word and then compares the two. If the same, the data is considered good.
I've also recently added support for the sustain pedal to the MIDI controller.
Currently, I am working on bringing the synth up to 8 voices.
cloudscapes
PostPosted: Thu Nov 08, 2012 11:35 am    Post subject: Reply with quote  Mark this post and the followings unread
holy cow! that last sample sounds amazing! really amazing!
DSP math is way over my head. I doubt I'd be able to produce anything as nice or complex even with a much more powerful micro. I'd brute force and botch it, inevitably.
what a great thread to follow!
Sonic Crayon DIY effects lab
JovianPyx
Audio files: 190
PostPosted: Thu Nov 08, 2012 4:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks cloudscapes Smile
But wait - there's more ...
I've added a second dsPIC voice engine, done a bit of troubleshooting and now I have an 8 voice DSP harp polysynth using 3 dsPICs. One is a MIDI controller and voice assigner and the other two are 4 string harp voice engines.
The sample provided is a MIDI sequence playing into the harp and I'm noodling the two knobs. The sample is completely dry.
You'll notice around 3:17 it starts to go really flat. That's a consequence of the karplus-strong model. I may throw in a display... - if I did I give it selectable tuning tables.
EDIT ADD:
Part of the technology in the MIDI controller is the re-use of a string if possible. That is, if I play a C and a G and then go back to the same C, that combination uses only two voices because the C is being "re-plucked", like a real harp. This means that for many applications, fairly complex chord rythms can happen with long sustain time with little if any discernable voice theft. This synth does do voice theft, but only as a last resort.
The whole Harpie synth
 Filesize:  229.16 KB
 Viewed:  166 Time(s)
Harpie Voice Engines Board
 Filesize:  140.18 KB
 Viewed:  156 Time(s)
dsPIC_Harpie_8_Voice.mp3
Sorry about the clipping (small amount), the output is a bit too hot, will be addressing that soon.
 Filename:  dsPIC_Harpie_8_Voice.mp3
 Filesize:  3.63 MB
 Downloaded:  433 Time(s)
audiodef
Audio files: 42
PostPosted: Thu Nov 08, 2012 4:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
Putting in a post to follow this thread - will listen later. Smile
Audiodef
Gentoo Studio
bubzy
Audio files: 63
PostPosted: Fri Nov 09, 2012 6:43 am    Post subject: Reply with quote  Mark this post and the followings unread
sounding good!
fell asleep a little bit there.
_Richard_ Smile
PostPosted: Fri Nov 09, 2012 7:15 am    Post subject: Reply with quote  Mark this post and the followings unread
That sounds AWESOME.
JovianPyx
Audio files: 190
PostPosted: Fri Nov 09, 2012 4:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here's a piece I did for testing the Harpie.
EDIT ADD: NOTE: DO NOT USE THIS ON THE RADIO. IT HAS CLIPPING. THE NEXT SAMPLE IS MUCH BETTER.
sg20121109a.mp3
My Brain Is An Electron
 Filename:  sg20121109a.mp3
 Filesize:  1.52 MB
 Downloaded:  406 Time(s)
PostPosted: Sat Nov 10, 2012 7:31 am    Post subject: Reply with quote  Mark this post and the followings unread
So when's the album coming out? Very Happy
ejr27233
PostPosted: Sat Nov 10, 2012 8:12 am    Post subject: Reply with quote  Mark this post and the followings unread
You have been paid the ultimate complement....My wife, listening from the next room thought it was a 'real' (ie accoustic) instrument!!
Fantastic project...please keep it up
JovianPyx
Audio files: 190
PostPosted: Sun Nov 11, 2012 6:28 am    Post subject: Reply with quote  Mark this post and the followings unread
Thank you both very much for your kind comments.
As for an album? heh, well, I am building up a collection of stuff, who knows...
And I am most certainly continuing work on this project and others like it. I'm trying to find out just how far I can push these little buggers.
