Request Snapshot from Nord Modular
Page 1 of 1 [19 Posts]
tomtakestooth
PostPosted: Thu Aug 19, 2010 9:18 am    Post subject: Request Snapshot from Nord Modular Reply with quote  Mark this post and the followings unread
Hi guys,
I seem to remember seeing something somewhere (possibly on this forum) about requesting a snapshot of all MIDI CC values from a NM patch.
I know this is possible by going through the menu on the NM, but is there a MIDI command that can be sent from an external controller to get this, as it takes a while to go through the menu and can get pretty annoying when performing live.
We've got a Behringer BCR2000 hooked up to it, and would be sweet if we could assign a button on there to send the controller snapshot over to the BCR2000 after selecting a new patch on the NM. Don't really know anything about sysEx, but am I right in thinking i could use that?
Any ideas?
Thanks
Tom
www.myspace.com/gumtakestooth
tomtakestooth
PostPosted: Thu Nov 25, 2010 7:49 am    Post subject: Reply with quote  Mark this post and the followings unread
after many hours looking around on here and other places, it seems this is not possible.... such a shame.
adnauseam
PostPosted: Fri May 31, 2013 12:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
This would be very handy. The results would be something like the G2's Patch variations.
I'm going to investigate this as well. I know you could at least get a constant snapshot from the knobs as long as they're assigned to MIDI CC values. Then you could keep track of the values as they're spit out.
There may not be a way to get module parameter values..
But now that I think of it.. Does changing a module parameter on the hardware unit with the rotary knob result in value changes in the software? That may be an alley to go down, but may require a kludge. Hmmmm. It may be that these module values are only transferred out the PC midi ports.
I'll think about it some more.
egw
G2 patch files: 8
PostPosted: Sat Jun 01, 2013 4:08 am    Post subject: Reply with quote  Mark this post and the followings unread
Unless you're going to run out of patch locations, you can just save each variation as a different patch, then send program change messages to switch between them. Of course the sound will not be continuous.
www.gregwaltzer.com
gomidas
G2 patch files: 6
PostPosted: Mon Jun 03, 2013 12:46 am    Post subject: Reply with quote  Mark this post and the followings unread
Try this for slot A, I've made it by recording the editor demo midi out but I can't remember if it's for the G2 or G1..
Patch Request Slot A.syx
 Filename:  Patch Request Slot A.syx
 Filesize:  8 Bytes
 Downloaded:  298 Time(s)
dean
PostPosted: Thu Jun 06, 2013 1:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
I've followed this forum for some time but thought this thread is a good time to chime in.
I have discussed this with the team at clavia who gave me their usual replies of 'not supported any longer'.
I have done a LOT of looking into requesting snapshots and how it works using a little 'observer' I created in max msp.
It seems that the sysex message that 'ctrl snapshot' sends is patch specific rather than channel specific.
My findings are this -
It is possible but it is patch specific, you'd have to use some sort of listener to figure out the snapshot request from each patch and send the messages from something like pure data or max msp.
I wanted this to restore a patch to its default state after changing many parameters (picture bringing the filter cut off and env paramater down and restoring them both with a quick hit of a button) but it was too much hassle creating different messages for each patch.
hope this gives some clarity to a long asked question.
cappy2112
PostPosted: Sun Jun 16, 2013 10:40 am    Post subject: Reply with quote  Mark this post and the followings unread
You could try using MidiOX (free) on Windows, it can be scripted.
You can also try Bomes for OSX, but it isn't free.
Both of these program can analyze incoming midi data and modify it to some degree. MidiOx lets you save sysex transfers to disk.
Yot
PostPosted: Wed Jul 13, 2016 6:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi guys,
Long time but I figured out how to ask for Controller Snapshot bypassing the Editor (at least for the Micro Modular).
The thing is that you'll have to use the Editor's Midi input and output (PC in and PC out) to transmit Sysex Messages.
To ask (to Nord Micro Modular) the CC Snapshots :
F0 33 5C 06 'xx' 55 'yy' F7
xx and yy are incrementing + 1 each time you load another patch.
When you power up the device :
xx = 00 (value 0)
yy = 5A (value 90)
The alternative is to get the xx value from the nord.
To get the xx and yy values, you have to listen the Sysex from the Nord Modular. Each time you load a patch, the beginning of the Sysex string is :
F0 33 50 06 XX <- Here's the good value.
So get this value for xx, add 90 to get yy.
To get things more complicated :
xx max is 3F (value 63), then it goes to 0
yy max is 7F (Value 127) then goes to 0
I made a max/msp patch to manage that. I can share it with you if you're interested.
Cheers.
Moody33
G2 patch files: 16
PostPosted: Sat Jul 16, 2016 12:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
Very Happy Thanks you Yot!
Moody33
G2 patch files: 16
PostPosted: Sat Jul 16, 2016 12:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
What about the "save in synth" sysex ? Could be useful to save modified patches ( with the assigned knobs only) on the fly. Do you think it's possible?
Yot
PostPosted: Sat Jul 16, 2016 12:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
Moody33 wrote:
What about the "save in synth" sysex ? Could be useful to save modified patches on the fly ( with the assigned knobs only). Do you think it's possible?
I can dig that!
Moody33
G2 patch files: 16
PostPosted: Sat Jul 16, 2016 1:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yot
PostPosted: Mon Jul 18, 2016 3:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
So... for "save in synth", the sysex command is
Hex: F0 33 5C 06 06 05 0B 00 00 xx yy F7
Values : 240 51 92 6 6 5 11 0 0 xx yy 247
Where xx = "Patch number - 1" (so patch 1 is 0 (hex:00), patch 2 is 1 (hex: 01) ...)
and yy= "Patch number + 80" (for patch 1 is 81 (hex:51), patch 2 is 82 (hex:52) ...)
The only thing I didn't get is that the name of the patch is well saved but not in the Editor Menu (when you make "save in synth" the normal way, it's the old name that is displayed.)
Moody33
G2 patch files: 16
PostPosted: Mon Jul 18, 2016 11:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
Great job Yot!
I will test it (do you?) later. I have a "CMU 2midi" midi interface I want to use to send sysex via an android app, but I'm not sure it will work because it seems to be not compatible with the editor. What is your midi interface?
Did you try to get the Sysex for patches Load when opening a .pch file store on the computer? The idea behind this is to have all nord patches on a tablet and be able to send them to the nord without the need of a computer.
Thanks you and sorry for my english.
Yot
PostPosted: Tue Jul 19, 2016 10:21 am    Post subject: Reply with quote  Mark this post and the followings unread
Moody33 wrote:
Great job Yot!
Yes, tested and works.
Regarding what you want to do with your tablet, it's not so easy but it should be feasible.
The .pch files are interpreted by the editor that converts them into sysEx messages. For your project, you will need to intercept theses SysEx messages when you load a pch file. No need to save in synth. As long as it's loaded, you should hear the patch from the MM.
To intercept messages, (as I do), you need to do a little trick like this :
MM PC out -> Computer Midi In 2
Computer Midi out 2 -> Computer Midi in 1
Computer Midi out 1 -> MM PC in
By this method, the messages that goes out of the editor are coming back to your computer then re-send directly to the MM. You can now listen the sysEx messages that are coming from Computer Midi in 2.
For each .pch, try recording the whole sysEx message sent to your MM. Save it and try to send the exact same SysEx message directly to the MM and see if it works. It should if everything is set properly. The MM is stupid. It should not make the difference. I'm pretty sure there is a SysEx message saying "Hello, I'm the Editor".
Keep us posted, this is a very interesting project.
Audio files: 231
G2 patch files: 319
PostPosted: Tue Jul 19, 2016 12:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
On my old website you may find (pointers to) useful information re. the subject.
http://www.iaf.nl/Users/BlueHell/index.htm
under 'nord modular' and 'nm open'.
You could also try to google for Marcus Andersson's patch loader software which may be of interest. Also of course http://nmedit.sourceforge.net/index.html which was the end result of all the information gathering.
Sorry, no direct solutions, but there is some old info out there which might save some work.
Audio files: 231
G2 patch files: 319
PostPosted: Tue Jul 19, 2016 12:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
Oh and also http://nmedit.sourceforge.net/developer.html
Moody33
G2 patch files: 16
PostPosted: Wed Jul 27, 2016 12:53 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks you Yot. I will take a look as soon as possible (I'm on Holiday...).
Thanks Blue Hell as well.
malmi315
PostPosted: Wed Apr 19, 2017 11:38 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm trying to "save in synth" in a G2 engine via sysex without luck. Any thoughts ?
Thank you in advance !
