Is there a need for a DSP calculator ? |
Absolutely |
91% |
[ 11 ] |
Yes, maybe |
8% |
[ 1 ] |
Maybe not |
0% |
[ 0 ] |
Certainly not |
0% |
[ 0 ] |
Total Votes : 12 |
Joined: Apr 03, 2004 Posts: 24085 Location: The Netherlands, Enschede
Audio files: 278
Posted: Fri Dec 03, 2004 6:50 am Post subject:
DSP calculator |
It's not easy to calculate the number of DSPs needed to be able to play a performance on the G2, e.g. whether it would fit on an unexpanded G2.
It's not easy to calculate how many voices a certain patch would give on an unexpanded G2, when creating it on an expanded G2.
Also it's not a very good idea to open up the G2 and remove the voice expansion in order to get answers on questions like this.
I think that for voice designers it would be helpfull to have a tool built into the editor to answer such questions.
Alternatively the exact allocation algorithm could be made public, so someone else could write a little calculator tool.
Jan. Last edited by blue hell on Fri Dec 03, 2004 7:59 am; edited 2 times in total |
Joined: Jan 31, 2003 Posts: 18198 Location: Durham, NC
Audio files: 213
Posted: Fri Dec 03, 2004 7:39 am Post subject:
I strongly agree with this. We get lots of posts from people asking about his. Most people find this confusing. Every time I understand it I discover I don't. This little calculator or monitor should be built into the editor, IMHO. _________________ --Howard
my music and other stuff |
Fozzie
Joined: Jun 04, 2004 Posts: 875 Location: Near Wageningen, the Netherlands
G2 patch files: 49
Posted: Fri Dec 03, 2004 7:53 am Post subject:
well, if you include voting options on this topic, I will choose the one that resembles "Absolutely! This is a thing that we are waiting for!!" mostly. |
Audio files: 278
Posted: Fri Dec 03, 2004 8:00 am Post subject:
Ok, go ahead !
Jan. |
Chet
Joined: Nov 19, 2004 Posts: 231 Location: Lititz,PA,USA
G2 patch files: 35
Posted: Fri Dec 03, 2004 2:04 pm Post subject:
I voted for "absolutely". I do a significant amount of off-line editing, and have gotten some nasty surprises when I finally hooked up my G2. |
egw
Joined: Feb 01, 2003 Posts: 1569 Location: Asheville NC
G2 patch files: 8
Posted: Fri Dec 03, 2004 2:13 pm Post subject:
I liked it on the old NM when the module choices in the editor would show you how much dsp they used. Often that would influence my choice of modules. With the G2 you have to put the module in the patch first to see how much it uses. I thought about making my own chart of what each module uses, but I discovered that it varies too much. For example in some cases the first instance of a module uses a different amount than subsequent ones. |
Audio files: 213
Posted: Fri Dec 03, 2004 11:00 pm Post subject:
The G2 uses some sort of dynamic resource allocation scheme. An oscillator with 3 FM inputs that are connected uses more resources than the same module with no inputs active. So the little pop up percentages wouldn't mean anything on the G2. _________________ --Howard
