  bingsatellites Mostly Ambient
 Forum index » Instruments and Equipment » iOS - iPad/Phone/Pod etc
Logic 9.1.1 and touchOSC problem
Post new topic   Reply to topic Moderators: mosc, v-un-v
Page 1 of 1 [5 Posts]
abstraktor
PostPosted: Fri Oct 01, 2010 3:07 pm    Post subject: Logic 9.1.1 and touchOSC problem Reply with quote  Mark this post and the followings unread
anyone else had problems with this combination? all latest versions of OSX, Logic and OSCulator - controller data is appearing at OSCulator, so the Touch/OSC is working via wifi, but Logic just wont get any MIDI notes or CC's in.
I thought I was going to get a mini Lemur on the fly, but I knew it was too good to be true!
any pointers appreciated folks. Crying or Very sad
abstraktor
PostPosted: Sat Oct 02, 2010 2:44 am    Post subject: Reply with quote  Mark this post and the followings unread
human error - got it running - i needed to assign values to the MIDI messages in OSculator and keep my eye on the lower note and higher note entries. Not exactly intuitive set-up...and a little bit of latency creeping in, but works fine.
phew. Need to borrow an ipad to test that out now Laughing
abstraktor
PostPosted: Mon Oct 11, 2010 4:46 am    Post subject: Reply with quote  Mark this post and the followings unread
I showed a colleague this set up-and he has used PD extended to map OSC messages to MIDI - which is rather cheaper than buying a non nag screen Osculator for £30 - dammit! Rolling Eyes
EdisonRex
Audio files: 168
PostPosted: Wed Oct 13, 2010 11:08 am    Post subject: Reply with quote  Mark this post and the followings unread
I was gonna say, I didn't have any problems with either OSCulator, or Touch OSC. But I haven't ended up using it much as it's still kind of fiddly. TouchOSC is a nice app, but requires some work to map the events.
Garret: It's so retro.
abstraktor
PostPosted: Mon Oct 18, 2010 1:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
no, i wouldn't say it was intuitive to set up - and it does ping from time to time which can trigger odd midi notes, but it's a nice little app for inputing midi via airport on the move. now for that pd learning curve!
emSynth
