1:11
Audio files: 109
Posted: Fri Oct 15, 2010 11:30 am Post subject:
Greetings, Folks!! Subject description: Introduction |
Howdy All!!
This seems like the place to be. Looking for a place to hang my hat and call home, and meet some like-minded folks.
i've been making "experimental" musick for around 18 years, but with a decade long "break". i've been taking it back up the last year, learning the new gear, ect. as when i was originally doing all this, computers were only used for sequencing. My main tools of destruction were JD800, MS10, Mirage, Bit1, Wavestation, a Roland sampler i forget the model #, Prophecy, and various toys ran through a Quadraverb.
Nowadays, im using Live, APC40, KaossPro, and all your regular virt synths, while using the older recordings for material.( i used to dream of a day when i could have all the gear i need in a backpack...FINALLY!!)
i've had a hard time describing what i do for the longest time. The best i can describe is i make musick for aliens. When i was sent to a VERY bad mental hospital as a kid, i would spend my nights fantasizing what kinds of musick aliens would listen to, running these aural textures through my head each night.
When i got older, i learned of various experimental artists through friends, and began a search for "that sound". Thousands of dollars of albums later, i finally ran into some noise makers who were really pushing the boundries. We instantly clicked and my life was changed forever. Since noone was making what i wanted to hear, it was up to me (us) to create that sound.
For about 8 years i pressed on, trying build the vision, but the technology hadnt caught up to what i needed yet. You only got 2 hands, 2 legs and that wasnt enuff. Technology now though, all things are possible.
i cant say i've reached a proper level a representation yet, im still fresh to the tech, but the recent recordings are getting much closer to whats in the head. What i get into is thick flowing textures, soundscapes, that are presented clearly with as little compression as possible, attention paid to aural bleeding/smearing, dynamic. Tired of the sonic assaults bordering on white noise, like things clearer and electric.
My current project is called AcidTrash.
Pleasure meeting you all,
1111
Audio files: 278
Posted: Fri Oct 15, 2010 11:48 am Post subject:
_________________ Jan
Posted: Fri Oct 15, 2010 1:22 pm Post subject:
As a Live user looking for oddish sounds, I just "invested" in puremagnetik's Waveform release for Live. It's a comprehensive sampling of the Ensoniq Fizmo, with something like 1700 wave frames embedded in a handful of samples. Easy to use, and probably the only production synth created in the world that had no peer. And it's only $12.
Welcome! |
shanemorris
Audio files: 92
Posted: Fri Oct 15, 2010 1:32 pm Post subject:
to electro-music ! _________________ ElectroCasa |
Audio files: 109
Posted: Sat Oct 16, 2010 9:46 am Post subject:
Thanx for the Welcome, GreenHell, ShaneM, and JKSS!!
JKSS, appreciate the heads up on the virt Fizmo release, definitely will add that to the library
Shane, checked out your MySpace and watched the first vid and enjoyed it! You guys have an ear for placement, and work well together. One of your FBFriends, Steve Roach, is our towns exp. heavy weight, and had just played not too long ago.
Again, appreciate the welcome,
1111 |
EdisonRex
Audio files: 172
Posted: Sun Oct 17, 2010 1:34 pm Post subject:
looking forward to hearing stuff from you. _________________ Garret: It's so retro.
shanemorris
Audio files: 92
Posted: Sun Oct 17, 2010 1:39 pm Post subject:
1111 wrote: |
Shane, checked out your MySpace and watched the first vid and enjoyed it! You guys have an ear for placement, and work well together. One of your FBFriends, Steve Roach, is our towns exp. heavy weight, and had just played not too long ago. |
Hey thanks for checking it out. Yeah Im a huge Roach fan. I wish I was going to Sound Quest next week... but cant make it this time.
Drop in the chatroom sometime. Several of us here hang out there a lot. _________________ ElectroCasa |
Audio files: 109
Posted: Sun Oct 17, 2010 6:02 pm Post subject:
Appreciate the invite to Chat, i will definitely make an appearance sometime!!
Shane- You nailed the loci on the head, buddy!! If you change your mind about Quest, maybe you could me a holla and we can shake hands in realtime.
Edison- i'm almost finished with a new track that i could put up. im still learning about this site, and it seems there might be a way to post tracks here(?) i still need to do my research on whats all going on here.
But more importantly, WHAT is that beautiful interesting piece of gear you've next to you in your avatar!?! |
nobody
Posted: Sun Oct 17, 2010 7:41 pm Post subject:
Welcome to the nut-house, 1111.
I look forward to hearing your stuff. |
Audio files: 109
Posted: Sun Oct 17, 2010 10:27 pm Post subject:
thanx AD |
EdisonRex
Audio files: 172
Posted: Mon Oct 18, 2010 3:28 am Post subject:
Yes, you can post your music directly to the forums as attachments, which will get them onto the radio as well (one way or the other). You can also just post links.
Just keep reading. There's an awful lot going on here!
That is my Eigenharp Alpha. _________________ Garret: It's so retro.
Joined: May 16, 2005 Posts: 8933 Location: Birmingham, England, UK
Posted: Mon Oct 18, 2010 3:43 am Post subject:
It's a bit like that in this city!
Hi 1111. to electro-music.com _________________ ACHTUNG!
nobody
Posted: Mon Oct 18, 2010 6:04 am Post subject:
v-un-v wrote: |
Hi 1111. to electro-music.com |
I don't know... did Jan finally stop feeling blue? |
Audio files: 109
Posted: Tue Oct 19, 2010 10:36 am Post subject:
"Green" Blue Maybe a Freudian slip on my end! Must say i'm a bit green with all the talent here, but thats the perfect environment to step things up and learn more.
edit:remember now, i was thinking of Misfits song, Last Caress Green Hell. And the folks i'm green about are the ones building their own synths. i went back to school planning on learning how to build, but i can't get past the Math classes to save my life. Argh.
Howdy AudioDef and V-Un-V!!
Thanx for steering me in the right direction, Rex. Simple enough, should have a track or two up in a week. It should serve as a good reference point, a Before the site and After.
Awesome freaking site. |
Audio files: 109
Audio files: 278
Posted: Sat Oct 23, 2010 6:07 pm Post subject:
1111 wrote: | i'm guessing this is the way to upload files. |
1111 wrote: | FolksHateIt.mp3 |
I'm sure some would, there are some very troubled minds around
Listening now ... like it sofar .. halfway trough ...
Would be handy if you'd post tracks in the online music section next time, but just that .. handy .. no laws really .. it would make it show up on the media page (with default settings).
Listened through it now, still nice, will add it to the radio playlist
When you run out of disc quota here please let me know, I'll up the quota then ... erm .. would love to hear more that means _________________ Jan
Joined: Apr 24, 2009 Posts: 2492 Location: Bristol UK
Audio files: 495
Posted: Sat Oct 23, 2010 6:33 pm Post subject:
I love your track to bits!!!
Welcome to electro-music, F.
You don't mind if I call you F do you? _________________ Muied Lumens Sub Forum
Bandcamp |
Audio files: 109
Posted: Mon Oct 25, 2010 9:09 am Post subject:
Ok, i'll post on media page next, thanks Blue!!
Muied, you can call me whatever you want, but what is F? Glad you liked it |
Audio files: 495
Posted: Mon Oct 25, 2010 11:03 am Post subject:
1111 wrote: | Muied, you can call me whatever you want, but what is F? Glad you liked it |
It's a very nerdy joke: 1111 in binary = 15 in decimal, or F in hex. _________________ Muied Lumens Sub Forum
Bandcamp |
Audio files: 109
Posted: Mon Oct 25, 2010 11:57 am Post subject:
Very Cool!! Love it!! You can certainly call me that |
nobody
Posted: Mon Oct 25, 2010 5:22 pm Post subject:
So if I get angry because something broke, can I exclaim "1111 THIS!"?
In Linux, the dot represents the current directory, kind of short-hand for "here" or "this". So I can represent my anger at the broken object by exclaiming "1111 .!".
I gets weird if you look at the exclamation point as the negatory in many programming languages. |
Audio files: 109
Posted: Mon Oct 25, 2010 5:28 pm Post subject:
haha, 1111 this....im gonna start using that, even though i is a math moron!! |
Posted: Mon Oct 25, 2010 9:49 pm Post subject:
All it takes is using your imagination!
(That'd be another math joke) |
nobody
Posted: Tue Oct 26, 2010 6:36 pm Post subject:
Ego is a fiction, and this is proved mathematically through i. |
Audio files: 109
Posted: Thu Oct 28, 2010 10:04 am Post subject:
whawhawhaaaaw hehe The only math tomfoolery ive ever done is taking the letters and #'s on license plates and doing acrobats to turn whatever it says into 75 (band was 75 million Changs). i LOVED doing that, and i actually enjoy doing simple math. But right now, i need to find a good math teach. The current one speaks with a thick Russian accent which makes it a bit hard. Ugh.
What letter would 111 be, doing the same binary to hex? |
