Posted: Mon Oct 25, 2010 10:35 am Post subject:
What's your Favorite Sequencer? Subject description: vintage, modern, both and/or why
So what have you used and like? I'll start it off:
P3 - Midi Sequencer
Had it for a while but didn't like the menu diving. Very powerful but didn't suit my work flow.
Schrittmacher - Midi Sequencer
Love the big screen, easy to program and use. Negatives are updates...there are none! and there is no real song mode for chaining long sequences It's still a joy to use.
MC-4 - CV Sequencer
I can not live with this guy in modularland. Timing is dead accurate, you get the 4 channels and can score to your imagination with those channels. Drawbacks for some might be the programming (10key), results are not immediate, it's big/bulky and has no memory save (not an issue with an MP3 recorder). MC-4's are also hard to locate.
TB-303 - CV Sequencer
Not a dedicated sequencer per say, but you can use the CV & Gate Out for sequences. I haven't explored this option much, but seems functional.
Your PC/MAC - Midi Sequencer
Had to mention this one
That's pretty much what I'm familiar with. Midi sequencers aren't so much a problem interfacing with analog gear as you can use a midi/cv converter. Curious to see what others have used and/or are currently using. Anyone use the ARP Sequencer?
And:
The sequencers in the NM-1 are quite nice too.
And:
http://www.five12.com/n2.html
Brilliant! _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Reason; Because it is unique, there is nothing else like it out there, it writes the ideas for you, and best of all, it was a joint collaboration by members of this forum! _________________ ACHTUNG!
Joined: May 16, 2005 Posts: 8902 Location: Birmingham, England, UK
Posted: Mon Nov 01, 2010 3:45 am Post subject:
BobTheDog wrote:
just downloading the demo..
Good luck! Be warned though, you'll be crying into your beer soon especially when the bill for your imminent RSI treatment bill comes through the letterbox! _________________ ACHTUNG!
Posted: Mon Nov 01, 2010 3:48 am Post subject:
BobTheDog wrote:
Mines in a box in many pieces!
What you have mines in a box???
So is mine - it's easy not to solder when you have YouTube
Joined: Feb 04, 2005 Posts: 2129 Location: Nottingham, UK
Audio files: 150
Posted: Mon Nov 01, 2010 5:32 am Post subject:
I've got some of my best stuff done using the P3 so I guess it is my favourite. There is too much menu diving it is true, but I find it is just about worth the effort _________________ Jez
music | adventures in sound
Actually, I have two unfinished cabs each with a Klee here.. slow progress. The Klee is brilliant and even more brilliant than it is possible to put into words when combined with the dotcommie sequencers and Numerology.
However, personally I tend to think of the Klee as an advanced interactive stepped event generator ( AISEG ?) and not quite something that is appropriate to just label as a plain sequencer. _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Oh, that came out wrong. The Klee is brilliant on its own of course.
I meant to say that from a modular synthesist´s viewpoint obviously one of the first ideas that comes to mind is to sequence (of sorts ) the Klee. _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Joined: Mar 28, 2006 Posts: 1190 Location: Kansas City, Mo USA
Audio files: 27
Posted: Mon Nov 01, 2010 11:03 am Post subject:
The Klee is the first thing that comes to mind.
I built my first Klee last summer and have a second one that is 75% finished.
I view the Klee as a real-time-composition device -- to call it a step-sequencer would be to understate it's capability. _________________ -- Kevin http://kevinkissinger.com
rather than start a new thread, I thought this one might be the place to ask..
I want to add a dedicated analogue/cv gate sequencer to my modular set up. I'd rather use a standalone -because I dont want to have to buy another case for a eurorack module, so I've been looking at the oberkorn from AnSol and (of course) waiting...and waiting for the Doepfer Dark time to gather reviews or (gasp) even a release.
I'd love a Klee but haven't the time or skill to build one. Vintage ARPs, Rolands and Korgs are too expensive, so I'm stumped.
Does anyone have any suggestions or feedback on the oberkorn?
Kind of off topic, but I downloaded the try out of the Klee VST on my mac for transfer to a xp pc, but I'm getting increasing problems with corrupted data on usb sticks between platforms. sinister.
Actually, a mac mini is quite useful for a lot of stuff. It is easy to open the cab and connect a larger/faster drive instead directly. And you can easily improve the life expectancy of the device by adding better cooling and such. And It easily fits inside a modular synth cab. _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Numerology is not really possible to recreate in a meaningful fashion using current sequencer modules. You would at least need several rooms full of modules before you get even close . A serious rig with a mac mini, a display , Numerology and interfaces will soon be far less expensive than a couple of 96x style sequencers and the necessary utility modules.
It is of course quite possible to combine analog sequencers with Numerology. That´s what I´m doing here. _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
I forgot to say that Numerology works fine with the Novation Launchpad.
Numerology can also feed Motu´s Volta.
http://www.five12.com/t-volta.html _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Numerology looks cool, but the last thing I need is another computer in the apartment (2 macs, 2 pc's already). And although Volta and Silent Way seem attractive, I really want to generate sequences "on the fly" and off-line before I hook up clocks to the DAWs. Kilpatrick Audio's pattern generator was interesting me , but I've decided not to expand the eurorack just now -mainly because of the case issue - and space.
I tried out Noatkl but it didnt suit my workflow, which is why I'm looking for something which has more of a directly conntrolled randomness (if you know what I mean).
Trying to break a writers block!
thanks for the feedback though....
I still havent started on my WSG build yet, so the Klee would end up as even more parts sitting in cartons on the kitchen table.
Joined: Sep 20, 2005 Posts: 272 Location: Tucson, AZ, USA
Posted: Sun Nov 21, 2010 1:07 am Post subject:
Sometimes I think I should change my user id to "sequencer junkie"... Heehee!
I'll add a couple to the list. First, my favorite sequencer is strictly DIY, but if you can handle a soldering iron, you just can't beat the MIDIbox sequencer! Maybe the new Cirklon will compete, but I haven't had a chance to try one yet. I have two P3 sequencers, and they're very capable, but I find the MIDIbox sequencer is more immediate and has similar power.
The Dopefur MAQ16/3 is a fantastic little sequencer. Easy and quick, but not in the same league as the MIDIbox or P3. I use two MAQ16/3s in my rig. Make each row a different length for longer evolving patterns...
For you analog types, the Milton is a pretty nice sequencer, especially if you use the redesigned bank boards that allow the banks to be different lengths.
Numerology and Volta and/or Silent Way are really good tools to check out as well...
Oh yeah, I have a couple Klees too! _________________ Once you start down the modular path, forever will it dominate your destiny!
Posted: Tue Nov 23, 2010 8:57 am Post subject:
Favorite Sequencers Past and Present
My favorite hardware MIDI sequencers back in the day were Ensoniq's pattern-based sequencers. The ESQ-1 on up to the TS-10. Loved them.
From 2002-2006 I used a mixture of software sequencers - FL Studio, Sonar, and Ableton Live.
In 2006 I switched 100% to Ableton Live 6 and haven't looked back. Live's piano roll is no where near as sophisticated as many, but the entire session view work flow and the ability to sequence, sample, re-sample, add tracks with vsts - all on-the-fly without a hiccup from the audio engine really suits me. Also starting in Live 8, you can do step-sequencing which was something I missed from the Ensoniq days. Here is a video I put together on it http://www.modulatethis.com/2009/04/ableton-live-8-step-sequencer.html.
I also use Tenori-On as my on-the-go scratchpad. I use it to drive VSTs in Ableton Live, to sequence Multi-Mode on my Waldorf Blofled and will soon use it to sequence synths on my iPhone. _________________ Mark Mosher
Synthesist, Composer, Keyboardist, Performer
Boulder CO
http://www.markmoshermusic.com http://www.modulatethis.com
Posted: Tue Nov 23, 2010 1:32 pm Post subject:
Thesys on sale
DES wrote:
Anyone using THESYS by Sugar-Bytes? I've been looking at it and the s/w Klee as well.
I've not tried but like other products like Artillery 2. Note they are having a big xmas sale. _________________ Mark Mosher
Boulder CO
Please support our site. If you click through and buy from our affiliate partners, we earn a small commission.
