ChucK shell - code read/add questions
mpw
PostPosted: Fri Nov 05, 2010 7:54 pm    Post subject: ChucK shell - code read/add questions Reply with quote  Mark this post and the followings unread
Anyone familiar with the ChucK shell should hopefully be able to help me...
I am trying to read a .ck source file into the ChucK shell and then add it to the virtual machine.
As I understand, the technique as follows:
Code:
chuck --shell
chuck %> code read file.ck test
chuck %> code add test
This should add the code from file.ck into the default VM that ChucK starts.
HOWEVER
When I attempt this, I receive an error along the lines of:
Code:
[tmp.0.Jn8KOnp]: syntax error
[chuck]: skipping file '/var/tmp/tmp.0.Jn8KOnp' for [add]...
add: error: command failed
I know there aren't actually syntax errors in the code for file.ck, because I can type 'chuck file.ck' and it runs without problem.
Any ideas?
