  bingsatellites Mostly Ambient
Presets Don't Set Delay - By Design?
Page 1 of 1 [3 Posts]
kellerpj
PostPosted: Sat Nov 27, 2010 8:35 pm    Post subject: Presets Don't Set Delay - By Design? Reply with quote  Mark this post and the followings unread
Howard/Robin:
Indeed, the AmbiophonicDSP is a new dimension in listening for me. I'm re-experiencing many recordings that I've listened to for years.
However, I'm wondering why the presets don't seem to set the Delay setting. Is this by design? If not, do you know if there is anything I should try to get the presets to "set" the Delay setting?
For your information, I'm using SAVIHost as my VST host. Its input is from Virtual Audio Cable. The output of the AmbiophonicDSP is set to my audio soundcard speaker outputs. I'm running Windows 7 Home Premium as my OS.
Thanks much in advance,
Paul
janderclander14
PostPosted: Mon Nov 29, 2010 3:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes, same problem here.
I've been requesting a solution to this issue for a year and still no answer Sad
melomane
PostPosted: Tue Dec 07, 2010 10:41 am    Post subject: Reply with quote  Mark this post and the followings unread
same here with WinXp and console or vsthost
also, balance not saved ...
i don't think than useful to store delay and balance in preset
BUT it is necessary to load the LAST values used.
JuneSolstice2013
