tranzash
Posted: Tue Dec 21, 2004 4:47 pm Post subject:
Voice area vs Effects area |
Is it ok to use effx(comp, rev, chorus) in the voice area instead of effx area?. Does it take too much dsp or should I use all the effx in the Effx area I'm too lasy to put another input/output modules in effx area. |
ian-s
Joined: Apr 01, 2004 Posts: 2670 Location: Auckland, New Zealand
Audio files: 42
G2 patch files: 626
Posted: Tue Dec 21, 2004 6:24 pm Post subject:
It makes no difference at all if your patch is monophonic. And there are no rules, but a verb takes close to 30% of your total dsp for a slot. If you want to maximise voices in poly mode, use the FX area. Sometimes putting stuff in the ‘wrong’ place creates nice accidents though.
Cheers |
tranzash
Posted: Tue Dec 21, 2004 6:36 pm Post subject:
g2ian wrote: | If you want to maximise voices in poly mode, use the FX area.
Cheers |
Hey nice tip, thanks |
Posted: Tue Dec 28, 2004 3:46 am Post subject:
Re: Voice area vs Effects area |
tranzash wrote: | Is it ok to use effx(comp, rev, chorus) in the voice area instead of effx area?. Does it take too much dsp or should I use all the effx in the Effx area I'm too lasy to put another input/output modules in effx area. |
It realy depends on what you are trying to accomplish. For some things it will not matter that much, for example if you put a reverb as your final stage in the sound then it shouldn´t realy matter and it would be more cpu efficient to put it in the effects section. For other things like overdrive it will matter a lot. All waveshapers depend on the input volume and baring extremely rare cases mixing multiple voices will lead to more volume and so a larger amount of waveshaping. Unless you are sure of what you are doing and have a good reason I think you should put your compressor in the fx section. Choruses have a internal lfo and so using them in the voice section will lead to having as many lfo´s as you have voices, that means the effect will be quite different depending on your choice.
Aesthetically it will also depend on what your polyphonic patch is meant to express. Using a lot of modules in the effects section will lead to a more unified sound that will sound more like it´s one instrument playing chords while only using the voice section might sound more like it´s several instruments playing monophonic lines together. _________________ Kassen |
