  Faux Pas Quartet and friends Music From Last Thursday [rebroadcast]
BUTT, a streaming tool for win, mac and linux
Page 1 of 2 [30 Posts]
Audio files: 116
G2 patch files: 317
PostPosted: Thu Dec 30, 2010 2:14 pm    Post subject:  BUTT, a streaming tool for win, mac and linux Reply with quote  Mark this post and the followings unread
EDIT: see http://electro-music.com/wiki/pmwiki.php?n=Radio.BroadcastingInfo for more on how to broadcast on electro-music.com.
MrCold pointed me to a new (FREE Wink ) streaming tool that seems to be capable to replace edcast. It seems suitable for Windows, Linux and Mac. I've tested a bit under Windows Vista, and Cody tried it on Linux - it seems to work.
BUTT
http://butt.sourceforge.net/
then navigate a bit to something like :
http://sourceforge.net/projects/butt/files/butt/butt-0.1.12/
for the windows exe and the mac dmg - the unix source seems to be available directly from the first link.
Audio files: 116
G2 patch files: 317
PostPosted: Thu Dec 30, 2010 2:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
Oh .. and it works with sc_trans too! (just use username:password for the password then).
DES
Audio files: 6
PostPosted: Thu Dec 30, 2010 3:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
Good news!
Do you think it safe enough to use for the Streaming Concert? (assuming the initial connection test is ok)?
www.davesneed.com
www.myspace.com/desneed
Audio files: 116
G2 patch files: 317
PostPosted: Thu Dec 30, 2010 4:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
If you now have edcast up and running and tested with that I'd use edcast .. if you don't have anything yet ... it better be good (the butt thing) Laughing
I tested it for maybe 15 minutes, that worked ok.
DES
Audio files: 6
PostPosted: Thu Dec 30, 2010 4:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
Makes sense. Edcast is known to work.
www.davesneed.com
shanemorris
Audio files: 83
PostPosted: Thu Dec 30, 2010 6:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
looking forward to testing this after nye Laughing
ElectroCasa
nobody
PostPosted: Thu Dec 30, 2010 8:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'll be checking this out, fo shizzle! Anything called "butt" has to be alright...
Audio files: 116
G2 patch files: 317
PostPosted: Fri Dec 31, 2010 10:19 am    Post subject: Reply with quote  Mark this post and the followings unread
For people wanting to experiment with sc_trans, there is an sc_trans testport set up. To connect to it use:
port : 9878
password : public:public
To listen if it works you can tune in to port 8054.
The test port can be used at all times, but only one connection at a time of course.
nobody
PostPosted: Fri Jan 07, 2011 7:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
BUTT segfaulted when I tried to run the native Linux binary. Shocked
Audio files: 116
G2 patch files: 317
PostPosted: Fri Jan 07, 2011 8:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
There seem to be some issues under windows too, with chipmuks on some audio in selections. Didn't have that myself though.
nobody
PostPosted: Sat Jan 08, 2011 10:28 am    Post subject: Reply with quote  Mark this post and the followings unread
When I ran it through Wine, I could see the meter bouncing without having put anything through it. Maybe this is the same thing you've heard of.
nobody
PostPosted: Sat Mar 19, 2011 10:00 am    Post subject: Reply with quote  Mark this post and the followings unread
Will try the Unix source. There's also IDJC, which I've installed but haven't used yet.
Audio files: 217
G2 patch files: 93
PostPosted: Fri Jul 15, 2011 11:50 am    Post subject: Reply with quote  Mark this post and the followings unread
I've wanted to check out how to setup butt a couple of times. Instinctively I open the "Streaming Radio Station" forum and do a text search for "butt", expecting to find a thread called something with butt. No such luck. Wink
Sure, there are other ways to find this thread, but still - would it be possible to add the magic word "butt" to the subject of this thread, in addition to the rather anonymous and increasingly inaccurate current title?
Audio files: 116
G2 patch files: 317
PostPosted: Fri Jul 15, 2011 11:51 am    Post subject: Reply with quote  Mark this post and the followings unread
That may me possible .. let mew try.
Audio files: 116
G2 patch files: 317
PostPosted: Fri Jul 15, 2011 11:53 am    Post subject: Reply with quote  Mark this post and the followings unread
It worked :-)
Audio files: 217
G2 patch files: 93
PostPosted: Fri Jul 15, 2011 12:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Very Happy cheers
Audio files: 153
PostPosted: Thu Sep 22, 2011 3:28 am    Post subject: Reply with quote  Mark this post and the followings unread
How does one use BUTT to play a file already on the server?
music | adventures in sound
Audio files: 116
G2 patch files: 317
PostPosted: Thu Sep 22, 2011 6:24 am    Post subject: Reply with quote  Mark this post and the followings unread
What do you want to do exactly Jez?
The answer may not be BUTT ...
Audio files: 153
PostPosted: Thu Sep 22, 2011 6:41 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm not sure exactly what I want to do, but I seem to recall people talking about being able to play files on the server, probably using sc_trans or something, but I don't really know where to look to find info on how this is done
Audio files: 116
G2 patch files: 317
PostPosted: Thu Sep 22, 2011 11:07 am    Post subject: Reply with quote  Mark this post and the followings unread
You'd do that by creating a playlist on the server, and then set sc_trans to play that playlist. I'll see if there is something written about that in the stream-ops forum, if not I'll write up a lil something.
Audio files: 153
PostPosted: Thu Sep 22, 2011 1:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Jan Smile
Audio files: 116
G2 patch files: 317
PostPosted: Thu Sep 22, 2011 3:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
Done, it's a sticky in the stream ops forum.
Audio files: 22
PostPosted: Sat Dec 03, 2011 6:38 am    Post subject: Reply with quote  Mark this post and the followings unread
Before I go testing my port for NYE 2011, BUTT is still the preferred streaming software right now? Been off the air for a while and out of touch and want to make sure. Also, to make changes to the artist info and picture that appears at the top of the main radio page, where do I go to do that? I use to have a link with a PW to do this.
Thanks for being patient with my questions.
Bill
Audio files: 116
G2 patch files: 317
PostPosted: Sat Dec 03, 2011 8:25 am    Post subject: Reply with quote  Mark this post and the followings unread
BUTT is OK, except on 64 bits windows for some it seems. Also sent you a PM Bill.
Audio files: 22
PostPosted: Sat Dec 03, 2011 10:57 am    Post subject: Reply with quote  Mark this post and the followings unread
OK so one last dumb question, I still have Edcast installed and was streaming just fine the last time I used it, can I use that? It is Shoutcast compatable also.
Bill
JuneSolstice2013
