 Forum index » Clavia Nord Modular » G2 Patches - Completed » Audio In
Stereo Delta-Modulation CoDec
stock
G2 patch files: 10
PostPosted: Tue Feb 01, 2011 11:18 pm    Post subject: Stereo Delta-Modulation CoDec Reply with quote  Mark this post and the followings unread
for LoFi lovers here is a stereo version of the delta-modulation algorithm with built in "noise sampling corruption" control.
Process the IN1/2 audio signal. if there is no signal, you can hear the typical "hiss noise" of the algorithm.
controls are :
- sample frequency
- delta increment
- noise control
- post filter
- input & output levels
Delta-Modulation.pch2
delta-modulation CoDec with built in "noise sampling corruption" control
 Filename:  Delta-Modulation.pch2
 Filesize:  2.34 KB
 Downloaded:  413 Time(s)
stk
