  Paulo Santos Synth-ing NºX
Backlog Free "Special Timbral Generator" DIY
Page 3 of 3 [69 Posts]
Goto page: Previous 1, 2, 3
questionable
PostPosted: Thu Feb 24, 2011 7:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
If you can get everything worked out, I'd be in for a PCB or two as well.
TekniK
PostPosted: Fri Feb 25, 2011 5:54 am    Post subject: Reply with quote  Mark this post and the followings unread
amnesia wrote:
I am interested in PCBs, parts and or faceplate completed or not if it looks and fits into Buchla boats Smile This has been a dream for me to play on a 259 Smile
http://www.youtube.com/watch?v=dSddgYKtPBE
tlu
PostPosted: Sat Feb 26, 2011 9:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
Definitely interested in some boards!!!
mono-poly
PostPosted: Mon Mar 21, 2011 5:25 am    Post subject:   Reply with quote  Mark this post and the followings unread
Rolling Eyes
TekniK
PostPosted: Mon Mar 21, 2011 8:49 am    Post subject: Reply with quote  Mark this post and the followings unread
surprise
oberkorn
PostPosted: Fri Mar 25, 2011 2:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm in for a board or two
Looks like I need more Rogan knobs... soon
toppobrillo
PostPosted: Sun Mar 27, 2011 4:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
guitarfool
PostPosted: Sun Mar 27, 2011 6:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm interested in one or two as well, especially if it's a bare or mostly bare PC. I pretty much have all of the original parts in stock including the obsolete ones. (through hole, anyway Wink ).
sduck
PostPosted: Sun Mar 27, 2011 6:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nothing from phdinfunk since February 18. I'm starting to think this project might not happen...
TekniK
PostPosted: Mon Mar 28, 2011 1:26 am    Post subject: Reply with quote  Mark this post and the followings unread
Ohm...
inform3r
PostPosted: Mon Mar 28, 2011 8:53 am    Post subject: Reply with quote  Mark this post and the followings unread
I have to agree with sduck on this one... Doesn't seem like it's gonna happen. Sad
phdinfunk
PostPosted: Sat Jul 16, 2011 6:49 pm    Post subject: Debugging...
Subject description: Troubleshooting is a really complex process....
Not "not going to happen" but yes, going unfortunately slow.
I'm definitely still working on this one, still got a board on the bench, and still trying to make it happen. Am about to bring someone else (or two) into the project to help out our original duo because I want to get this finished sometime soon.
I don't know if you'd prefer to be kept abrest of things blow by blow or if you'd prefer to just hear a little here and there until I tell you it's done and ready for public consumption.
--JP
tlu
PostPosted: Sat Jul 23, 2011 10:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
Definitely interested in this if it fits into a Buchla 200e boat. Thanks for taking the 259 on.
KEYKEYEYEKIT
PostPosted: Tue Aug 30, 2011 10:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hope this happens, really interested in a board or two.
hv0190
PostPosted: Sun Sep 04, 2011 8:21 am    Post subject: Reply with quote  Mark this post and the followings unread
Sounds interesting - should it really happen I'd be in for two boards.
phdinfunk
PostPosted: Sat Sep 21, 2013 4:30 am    Post subject: Reply with quote  Mark this post and the followings unread
These boards are finally completed, calibrated, tested.
Here are some sound clips:
1) The basic sampling of those famous 259 sounds. I switch different kinds of modulation and change the frequencies of both oscs. I twist mod index and all the different settings on the wavefolder. There's nothing but the 259 and its raw output going on here.
At 4:17, I add cross synchronization. Of course, you could go on for days with all this. I decided to stop the clip and do some more organized sounds to give people an idea of what a 259 actually does.
https://soundcloud.com/phdinfunk/twisting-a-lot-of-knobs
2) There is a lot of confusion about what the Symmetry system does on this synth. Here you can hear the Symmetry Control go from all even harmonics, though a saw-ish waveform, to all odd harmonics. Many harmonically rich "plain" waveforms exist between these settings.
Order and Timbre at 100%
https://soundcloud.com/phdinfunk/symmetry-sweep-order-100
3) Timbre control at 100% so you can hear what "order" does. It fades from the plain waveform (Symmetry Control) to the wavefolded waveform. If you set Timbre at 0%, you are always getting a low harmonic waveform (sine). Check the panel of a music easel and you will see this labelled pretty well.
Order swept with Sym at 50 ("Saw" like) then at 100 ("odd") then at 0 ("even") then at 50 again.
https://soundcloud.com/phdinfunk/order-sweep
4) This is the Timbre sweep of the raw waveform from Symmetry control. Very nice for simple synth sounds fading from a sine into a high harmonic waveform. So, with The wavefolder mix set to 0%, Timbre will simply sweep from a sine to a wave like a square or a wave like a saw. Again, see the music easel for a bit more clarity on this.
Sym 50 ("Saw" like) Sym 100 ("Odd") Sym 0 ("Even") and then Sym back to 50.
https://soundcloud.com/phdinfunk/timbre-sweep-order-high
5) Symmetry is at 50% (Saw-like wave).
First sweep, order is "High" so you get the plain waveform. Second Sweep, order is at 50% so you get a mixture between the plain wave and the wavefolder. Third Sweep, Order is "low" so everything is wavefolder. So, order controls mix between raw clean waves and folded waves.
https://soundcloud.com/phdinfunk/timbre-sweep-with-wavefolder
I hope this clears up any confusion about what these controls actually do. I have seen a lot of odd theories throughout the years.
I believe that a lot of people want to hear some sequences and tweaking or EG applied to different parts, so I have a step sequencer on the way, and a very nice MIDI to CV as well. I should have those sounds up in a week or so.
--JP
coolsynths.com
oberkorn
PostPosted: Sat Sep 21, 2013 11:40 am    Post subject: Reply with quote  Mark this post and the followings unread
awesome! it's finally happening!
it sounds good to me Smile
phdinfunk
PostPosted: Sun Sep 22, 2013 4:14 am    Post subject: Reply with quote  Mark this post and the followings unread
You should PM me. I have some overrun.
I'm also phdinfunk everywhere in the world, including the world's most popular not-evil email service.
-=JP=-
www.coolsynths.com
phdinfunk
PostPosted: Sun Sep 22, 2013 6:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
And bottom line, yes, they are expensive. I'm offering a few to DIYers here, just because my original intent was a DIY project for all. But at the end of the day, building them the way I have is not any cheaper for me than just building a completed synthesizer.
As a synth or module, it would be a great deal (compared to saaay, buying two triangle core oscs, a modulation VCA, and a waveshaper) but as DIY, it looks expensive. Though compared to boards plus parts kits for everything there, it's not so expensive.
I know someone else with a bare PCB project, if that's what you'd rather have, you can PM me and ask.
--JP
I'm phdinfunk everywhere on the web, including the world's most popular Not-evil Email service.
