<on air> Antimon Antimon Waves
 Forum index » DIY Hardware and Software » Synthasystem
Update
Post new topic   Reply to topic Moderators: dingebre
dingebre
PostPosted: Sun Feb 06, 2011 12:05 am    Post subject: Update Reply with quote  Mark this post and the followings unread
The update is:
All but one module has been prototyped, checked, and can be pronounced working!!!!!!
The one hold up is the Ring Modulator. It's a straight forward design built around an MC1495 multiplier. The chip is out of production, but I thought I had found a good source for the Motorola chips. Unfortunately, all the chips I bought seem to be bad, not forgeries, just bad...
I found another source who bought a TON (like 30,000) of the On Semiconductor version. I'm reasonably confident these ones will work. Then one last small production order for the last three PCBs, then FINI. I can then finally finish building the modular I started in 1975.
With the "modules" for the Synthasystem done, I can turn to the keyboards. I'll do the DuoPhonic keyboard, then likely the MultiPhonic keyboard.
After that, there is always the Microcon which I can do, and one other sequencer I think I would like to try. We'll see.
Let me know if anyone is interested in any of the modules and we can work out somehow to get you a PCB:
18 different modules to choose from, not quite Doepfer, but a lot more fun and strictly VINTAGE!:
Frequency Divider
Input Amplifier
Noise Source
Peak Selector
Phase Shifter
Ring Modulator
Sample and Hold (Dual)
Selective Inverter
Sequencer
Trigger Converter (Not strictly a Steiner design, but useful converting between S-Triggers and V-Triggers)
Triple Envelope Generator
Tuner/Monitor
Voltage Controlled Trigger Generator
VCA
VCF
VCO (type A with four waveforms or type B Square/Saw or Sine/Triangle)
Voltage Follower
Voltage Processor/Mixer
Thanks everyone!
David
dingebre@3dphysics.net
