 Forum index » Instruments and Equipment » OSX as a music workstation
KarmaFX Modular synth environment now for Mac OSX!
PostPosted: Sat Feb 12, 2011 4:43 am    Post subject: KarmaFX Modular synth environment now for Mac OSX!
Subject description: ported at last! 8)
I first mentioned KarmaFX in the Windows software section, when it was freeware. Now it's payware, but it's also been ported to Mac OSX. Huzzah!
KarmaFX Synth Modular: Advanced Simulated Analog Modular Synthesizer and Effect Unit.
# Full Modular patching of synth Components and Controls.
# Internal high-frequency digital simulation of analog voltage levels.
# Oscillator with phase, Detune and Pulsewidth that generates standard synth waveforms.
# Dual Oscillator with Detune, Hardsync and Ring modulation.
# Sampler, 16/24/32 bit Mono/Stereo multi sample player that imports WAV/SF2/SFZ files.
# Multisample editing with Key/Velocity-ranges and Loop-Points.
# Additive and Pad module with waveform and Harmonic Magnitude/Phase editors.
# User defined waveforms and built-in presets of up to 1024 harmonics.
# 2/4 Pole Multimode Filters with Cutoff, Resonance (LP, HP, BP and BS filtertypes),
# SVF, Zolzer, Moog, 303like, Formant, Comb, Allpass, Parametric and Shelving Filters.
# 10-band digital and 31-band simulated analog Graphic Equalizers.
# Amplifier and Stereo module with Panning, Volume and Velocity control.
# Two channel Mixer with Ring modulation and Bit operations.
# Delay, Reverb, Phaser, Chorus/Flange, Pitchshift, BitShuffler and Distortion effects.
# Soft-knee Compressor with Peak/RMS detection and optional Sidechain.
# 10 Octave/12 Note Pitch control with Detune, Portamento and Pitchbend support.
# Controllers for Frequency Modulation (FM) and fast frequency sweeps.
# Up to 16 channel Unison controller with Detune and Stereo pan spread.
# 32 step, 4 octave Pattern controller with Hold, Loop, Legato and Arpeggiator.
# Bipolar/Unipolar LFO with Tempo Sync, HFO with FM option.
# ADSR and Multipoint Envelopes with Linear, Exponential, Hermite and Cubic curves.
# Step Sequencer, Envelope follower, Sample & Hold and Decay modules.
# Output module with Panning, DC removal, Volume and Clip control.
# Noise generator, filtered Pink, White and Brown Noise with Frequency Sync control.
# Input generator so synth can function as an Insert effect.
# Full stereo support (selected modules can run in mono to save CPU cycles).
# Patches are built up of Generators, Filters, Amplifiers, Controllers, Effects and Modulators.
# Up to 49 simultaneously running modules (8 modules per group and 1 output module).
# Instant visual feedback on all controls. Frequency, Time/Amplitude, Modulation, etc.
# Optionally see knobs and sliders animate as they are modulated.
# Choose between Mono, Legato, or up to 16-voice true Polyphony.
# MIDI modulator modules for MIDI Controller, Velocity, Aftertouch and Pitchbend input.
# 128 user-assignable Automation controls with MIDI Learn.
# Fully skinnable GUI: Optional skins are bundled with the installation.
# 7 banks of pre-made KarmaFX patches + userbanks. (More than 1300+ patches total).
£80 gets you a Nord G2-ish modular for you Mac. Not bad eh? Cool
KarmaFX
ACHTUNG!
Niio1
