  Twyndyllyngs Live in person Chez Mosc
A6 Display Question
Page 1 of 1 [6 Posts]
jknievel
PostPosted: Tue Feb 15, 2011 10:14 am    Post subject: A6 Display Question Reply with quote  Mark this post and the followings unread
I powered my Andromeda up last night after not using it for awhile and noticed the display looked dim. Not sure if it's always been that way or perhaps I'm unfairly comparing it to the very bright green display on my MPC2500.
So... just wondering how bright the display is on your Andromeda.
JK
HrastProgrammer
Audio files: 71
PostPosted: Tue Feb 15, 2011 11:39 pm    Post subject: Re: A6 Display Question Reply with quote  Mark this post and the followings unread
By "dim" do you mean contrast or the backlight intensity? If it is cold then LCDs tend to have a lower contrast ...
I have 2x A6 and the display on the older one (around 2003. or so) has a little (and I really mean little) brighter backlight than a new one. Compared to the other synthesizers I have, I don't know, I don't see a significant difference between them, either in contrast or backlight. Some of them, like Waldorf Q or Yamaha FS1R have somewhat stronger backlights but the others are, more or less, all in the same league. The only real exceptions are TG77s, but I upgraded them to white-on-blue LCDs with LED backlight, so you can use them as a night lamp when needed Wink
http://www.hrastprogrammer.com/hrastwerk/
http://hrastprogrammer.bandcamp.com/
Last edited by HrastProgrammer on Fri Feb 18, 2011 5:13 am; edited 1 time in total
sunny pedaal
Audio files: 12
PostPosted: Thu Feb 17, 2011 1:21 pm    Post subject: Re: A6 Display Question Reply with quote  Mark this post and the followings unread
HrastProgrammer wrote:
I have 2x A6 and the display on the older one (around 2004. or so) has a little (and I really mean little) brighter backlight than a new one.
i have the same experience. the older one has the brighter backlight ( which i prefer ). i wonder if it's a big deal to make the newer one a bit brighter ?
HrastProgrammer
Audio files: 71
PostPosted: Fri Feb 18, 2011 2:40 am    Post subject: Re: A6 Display Question Reply with quote  Mark this post and the followings unread
Maybe raising up backlight voltage a bit. I know that in my case it wouldn't be worth a trouble because the difference is barely visible and the contrast is the same.
BTW, here is the picture of my studio in the dark, so various backlights can be compared:
http://www.hrastprogrammer.com/qozmyx/equipment.htm
Andromeda (the newer one) is right in front, below korg Z1. Unfortunately, the LCD on the older A6 on the right isn't visible ...
jknievel
PostPosted: Tue Feb 22, 2011 7:59 am    Post subject: re: A6 Display question Reply with quote  Mark this post and the followings unread
Thanks so much for the replies, I'm not going to worry about it since I can still read the display anyway. Maybe if I ever need any work done on the A6 I'll address it then. And Hrast, your setup looks incredible. Nice.
JK
HrastProgrammer
Audio files: 71
PostPosted: Thu Feb 24, 2011 8:24 am    Post subject: Re: A6 Display question Reply with quote  Mark this post and the followings unread
Thanks Very Happy
