For lunettas you can use them in just about anyplace you would normally use a divider, but they are a little more interesting because you can set-up static or fluctuating loops.
They divide the squarewave that goes to the input and a square wave with a lower frequency comes out at the output.
A basic divider is the cd4040 and it divides by 2, 4, 8, 16, etc. So it makes the output by every division by 2 an octave lower. That's all i can say about dividers, I hope it helped...
sorry, I guess there are no two ways of working with a lunetta that are alike, but, in general, you take 1 or more high frequency squarewaves, divide them, combine them with logic etc. shift registers are just another cog in the machine.
shift registers aquire data (the outputs of clocks, logic, dividers) & then store and/or distribute it, depending on the IC in question.
for what its worth, audio or 'music' or whatever kind of emerges from lunettas but its hard to think / talk about them in audio terms... just mess with the data till it sounds cool
Joined: Feb 02, 2009 Posts: 480 Location: new zealand
Posted: Sun Mar 06, 2011 12:58 pm Post subject:
Pasting from the document:
Shift registers have two kinds of inputs, Clocks and Data.
Think of clocks as usually regular predictable on/off streams. 1010101 over and over. Any oscillator can be a clock. It sets the timing for the shifting.
Think of Data as less predictable streams of highs and low. instead of 101010101, you can get stuff like 10010111100010010100110101001. See?
So a shift register is like passing a bucket of water down a line of people. The first person passes on a full bucket of water, and it goes down the line of people. Then he passes an empty bucket of water down the line. The clock determines the speed of the passing down the line of outputs, and the data input determines the high or low status being passed down the line of outputs. That's why we need logic gates to make interesting irregular streams of data to pass down the line.
You could up the clocks to audio rates and listen to the shift reg outputs.
Or build the 4051/4017 melody genereator and use the shift reg outpus as our A,B,C selectors.
Or send those through resistors(which results in varying analog voltages) into a VCO and listen to them. Any of your oscillators will be good for that, try making a slow oscillator and sending your voltage into the circuit at one of the legs of the potentiometer. The oscillator will wig out, make sure you're listening to it. If that's one of your main logic oscillators then it will flip out, good times good times.
And then your one logic gate output of interesting data gets turned into several outputs of interesting irregular data. LEDs will help visualize what's happening there.
Some people do 'white noise' generation with shift registers too, take some speedy signals, run them through some gates and send them through the shift reg, and then connect some of the outputs back into the gate inputs for data feedback, not sure how else to describe that. _________________ ==================
https://docs.google.com/Doc?docid=0AZIwOP-PR9sSZDlidzgzbV8wY3RjenJqanY&hl=en
basically the best advice I can give anyone is to get a breadboard and just experiment. As long as you got your power connections in place you can try pretty much anything you want.
I've had some successes with using diodes, LED's, LDR's and all kinds of parts between different pins or IC's.
And in general I think LED's are invaluable for their visual feedback of the different datastreams.
just have fun _________________ There he goes. One of God's own prototypes. A high-powered mutant of some kind never even considered for mass production. Too weird to live, and too rare to die.
Hunter S. Thompson movies noise
(plus that whole website is suuuuuper useful and one of the best resources on the interweb)
shift registers need to be played with, honestly they allow your lunetta to just go nuts even harder. _________________ home made noise and electronic ill-logic
Posted: Thu Mar 17, 2011 6:41 am Post subject:
Thanks
Thanks guys. That falstad example really helped. Now I just have to order a bunch of these babys. Is it economically feasible to order 10 of each one of the cd4000 series?
In theory, yes. In practice it's a lot smarter to buy when you need them. I started with "ten of each" of the most common IC's and I still have a lot of them left without any real use for them. IC's are light and cheap, if you can find a webshop wich will ship them through regular letter sized mail you can get the IC you want in under 2 days, and it's cheaper than having a huge stockpile laying around. _________________ There he goes. One of God's own prototypes. A high-powered mutant of some kind never even considered for mass production. Too weird to live, and too rare to die.
Posted: Fri Mar 18, 2011 10:07 am Post subject:
Re: Shift registors? What are they for?
Oweng4000 wrote:
Just wondering, what do shift registers do as far as audio? Everyone has one in their lunetta, but i'm very confused as to what they do.
4031 is a fun and easy to understand one - basically it is a fixed 64 step clocked logic delay. It can be looped back into itself to make 64 step repeating patterns (on/off values only).
i've used the 4031 as a weird buffer repeater thing for glitchy effects and also as a 64 step sequencer, if you AND gate the output with the incoming clock. 64 step patterns! sure beats a 4017... although you dont have access to each bit separately it's good for longer patterns.
Curious about this part - why do you need to AND gate the output with the clock?
for triggering of sounds, say a drum circuit or an envelope generator.. or to clock a shift register or counter or another sequencer; as examples. otherwise sequential ON steps will 'bleed' together as one long gate instead of discrete steps.
Posted: Fri Mar 18, 2011 11:26 am Post subject:
Psyingo wrote:
for triggering of sounds, say a drum circuit or an envelope generator.. or to clock a shift register or counter or another sequencer; as examples. otherwise sequential ON steps will 'bleed' together as one long gate instead of discreet steps.
Oh, right on, I get it now. I have used more as a "realtime" recorder, like in the video, so holding high states for their duration is good in that case. _________________ ∆ A. MAGIC PULSEWAVE ELECTRONICS ∆ A MAGIC WHISTLE ∆
if you want to use it as a realtime recorder for percussion i would suggest the AND gate method. holding the note would actually provide retriggering.
Please support our site. If you click through and buy from our affiliate partners, we earn a small commission.
