  bingsatellites Mostly Ambient
Dead key on Nord Lead 1 - help!!
Page 1 of 1 [4 Posts]
sleepypinwheel
PostPosted: Fri Mar 25, 2011 5:46 pm    Post subject: Dead key on Nord Lead 1 - help!! Reply with quote  Mark this post and the followings unread
hey, just got a Nord Lead 1 today and after about a couple of hours or so of playing it one of the keys went silent. I was admittedly pounding the keys pretty hard, although i have to say i'm quite surprised.
the key is still intact and when i opened the hood the spring is reacting the same as the other keys. so i'm guessing it's an issue with the electronics.
any possibility this is something i can fix myself/how to fix? should i return the synth?? it was a pretty good deal, and i was pretty blown away by it at first.
any info would be much appreciated. thanks in advance!!
m0ton3
PostPosted: Tue Apr 05, 2011 2:13 am    Post subject: Reply with quote  Mark this post and the followings unread
I also bought an NL1 with dead keys but was able to repair it. Mine had some damaged wires on the keyboard PCB, I fixed it by soldering small wires as bypass. I had to reapply the conductive coating of the key contacts (see below).
I bet you problem is caused by just a bit of dirt on those carbon contact under the key. Try to clean it with pure alcohol. If the carbon coating itself is worn or damaged you can replace it by carefully scratching it off and applying new conductive coating like CaiKote 44 (that's what I have used).
Good luck!
EDIT: see also arrow http://electribe-forum.com/viewtopic.php?f=6&t=249&p=1589
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Tue Apr 05, 2011 3:06 am    Post subject: Reply with quote  Mark this post and the followings unread
Hmm...
How blunt I am.
Just forgot to answer or at least a welcome...
So to the both of you
welcome sleepypinwheel and welcome m0ton3
Wout
m0ton3
PostPosted: Tue Apr 05, 2011 6:12 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks albino
emSynth
