 Forum index » Instruments and Equipment » iOS - iPad/Phone/Pod etc
Oscilloscope for the iThing
Post new topic   Reply to topic Moderators: mosc, v-un-v
Page 1 of 1 [5 Posts]
PostPosted: Wed May 04, 2011 2:42 am    Post subject: Oscilloscope for the iThing
Subject description: This one £8.99 8)
This looks more like it. £8.99 too!
Oscilloscope for iOS is a powerful digital Oscilloscope & Signal Generator app. Designed to plot audio signals, monitor equipment, analyze events, and test circuits, it is also an excellent learning tool. Its GUI includes many standard oscilloscope controls, such as: triggering, time and voltage per division, signal measurement cursors, and more. The app also incorporates a signal (function) generator capable of generating sine, square, triangle, and sawtooth waveforms of up to 22 KHz. Calibration to an external reference signal is supported, guaranteeing the accuracy of measurements.
Input is acquired via the built-in microphone or a probe connected to the headset connector. For best results one could use an external accessory such as a dock connector audio input device for the iPhone/iPod touch, or USB audio input such as Griffin iMic for the iPad.
Feature Highlights:
* Real-time waveform display (60 FPS)
* Triggering modes: Normal, Auto, Single
* Set trigger level and pre-trigger time
* Built-in function generator
* Reference signal calibration
* Pause function to get a screen capture
* Measure signal data using cursors
* Use "finger pinch" on screen to set voltage and time base
* Double tap screen to enter Black Panel mode
* Four color themes to choose from
* Retina display support
http://itunes.apple.com/gb/app/oscilloscope/id388636804?mt=8
ACHTUNG!
Audio files: 107
PostPosted: Fri May 13, 2011 8:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey, that's pretty cool. Perfect for simple projects and emergencies. Thanks for the link.
seraph
Editor
Editor
Audio files: 31
PostPosted: Fri May 13, 2011 11:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
what that obnoxious music has to do with that awesome oscilloscope application Question
PostPosted: Sat May 14, 2011 2:04 am    Post subject: Reply with quote  Mark this post and the followings unread
Laughing
ACHTUNG!
cappy2112
PostPosted: Wed May 18, 2011 3:48 pm    Post subject: Re: Oscilloscope for the iThing
[quote="v-un-v"]This looks more like it. £8.99 too!
This remind me of the intro to "The Outer Limits"
Do not try to adjust your television. We control your vertical. We control your horizontal Wink
Niio1
