Balanced Modulator troubles
Page 2 of 2 [28 Posts]
Goto page: Previous 1, 2
vcfool
PostPosted: Thu Mar 01, 2012 6:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
After some afternoon testing, I finally had to install the input resistors. Looks like the AC coupling caps would not discharge without those, and the AC mode wasn't working correctly.
I've attached a schematic of what I finally did to my inputs. Is this looking good? Sorry for my lack of electronics knowledge.
Thanks again!
YuSynth Balanced Modulator Input Mod
 Filesize:  2.35 KB
 Viewed:  784 Time(s)
Jaba
PostPosted: Fri Mar 02, 2012 2:42 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi vcfool,
yes, AFAIK your schematic is very good, and it works perfectly.
It actually is the same circuit I was suggesting as "option 1" in my message dated June 21st, 2011; no wonder we came to the same solution, I would say it's a standard one
Sorry for not answering sooner, but it's good to see that you found the correct answers on your own.
Jaba(Paolo)
vcfool
PostPosted: Fri Mar 02, 2012 7:07 am    Post subject: Reply with quote  Mark this post and the followings unread
Great!
Thanks once more for the answer and the improving modification.
Niio1
