ark
G2 patch files: 31
Posted: Wed Jul 27, 2011 2:56 pm Post subject:
Please confirm my understanding of Doepfer CV connections Subject description: Connecting Doepfer ribbon controller to Phatty |
I just got a Doepfer R2M ribbon controller that I want to use to make my Slim Phatty fretless, as it were. I knew that Doepfer uses 3.5mm connectors and Moog uses 1/4, but I had a cable with 3.5mm TRS on one end and dual 1/4 TS on the other, so I thought I was all set.
Well... I connected one end of the cable to the ribbon controller and the TS connector labeled "Tip" to the Moog and nothing useful happened. So I tried the connector labeled "Ring" and still nothing useful happened.
I next tried searching the documentation to see if it would explain how CV was connected to the connector. No joy. So I got out the voltmeter.
What the voltmeter suggests is that the CV is between the tip and ring conductors, and the shield floats. By implication, I should be able to use a cable with 3.5mm TS (not TRS) at one end and 1/4-inch TS at the other and all will be well.
However, if someone reading this is more familiar with Doepfer gear than I am, I would appreciate a sanity check on this belief while I wait for the appropriate cable to arrive from Sweetwater. |
BobTheDog
Posted: Thu Jul 28, 2011 3:41 pm Post subject:
| Well I have a Doepfer system amd have never used trs, just ts only. |
wmonk
Joined: Sep 15, 2008 Posts: 483 Location: Enschede, the Netherlands
Audio files: 12
Posted: Sun Jul 31, 2011 12:53 pm Post subject:
There might be two things going on here: the Moog requires a gate too to get sound, or another cable.
The doepfer website states:
| Quote: | 2 CV outputs (3.5 mm mono jack sockets, same as used in the A-100 system):
CV1 outputs the position sensor data (1V/octave standard, 0...max. +5V, i.e. max. 5 octaves)
CV2 outputs the pressure sensor data (0...+5V)
Gate output (corresponds to CV1, 3.5 mm mono jack socket, same as used in the A-100 system): | http://www.doepfer.de/R2M.htm
So you should be able to use a mono cable. I think the Moog needs that gate. I think that must be S-Trigger, and then you have to select that option inside the box with a jumper. _________________ Weblog!
Kits for synthesiser modules in Europe |
ark
G2 patch files: 31
Posted: Sun Jul 31, 2011 12:59 pm Post subject:
The issue wasn't the gate, it was that at the time I posted the original query, I simply did not have any cables with 3.5mm TS at one end and 1/4" TS at the other. I did have a cable with TRS at both ends, but that one didn't work; that's why I broke out the voltmeter.
Since then I have gotten my hands on some appropriately sized TS cables, and now all works as I would expect. |
EATyourGuitar
Joined: Oct 28, 2010 Posts: 45 Location: Providence, RI
Posted: Sun Oct 16, 2011 5:07 am Post subject:
| when plugging stereo cables into TS jacks you are gambling that they are not using stereo jacks with the ring and sleeve setup as a cable detector or switch. like say you had a cable you made that is a mono cable and you used a stereo jack at one end with nothing connected to the ring. when you use it to plug into a battery powered guitar pedal, the pedal will never turn on cause the ring floats. that pedal needs a real TS cable so the ring and sleeve of the jack get connected through the cable and provide power for the pedal. |
