TR808 kick pcb
Page 5 of 5 [114 Posts]
Goto page: Previous 1, 2, 3, 4, 5
Dougster
PostPosted: Thu Sep 22, 2011 6:42 am    Post subject: Reply with quote  Mark this post and the followings unread
fonik wrote:
so the single voice idea has died? will have to ponder about it a little bit...
Umm, what gave you that idea?
To be honest, at this point, I'm probably going to make all three variants... Cool The multi-voice boards will be first, since I'm pretty much done with them already. I still have to decide about the potentiometers, board sizes and mounting holes for the individual voices...
Once you start down the modular path, forever will it dominate your destiny!
Every DIY person should own a copy of Electronotes: http://electronotes.netfirms.com
Blue LEDs are evil.
PostPosted: Thu Sep 22, 2011 10:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Laughing
good to hear. i stay tuned...
fonitronik at
brother303
PostPosted: Thu Sep 22, 2011 12:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Doug,
wow,way cool!
Any idea when a run could happen?
Best regards
Greg
Dougster
PostPosted: Thu Sep 22, 2011 4:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
Two things need to happen before I make new boards. 1) This batch of MB-808's has to be out the door, and 2) I want to build prototypes of each new board before I order and ship the final versions. I'll be back from my business trip in mid October, so I'm hoping to get the MB-808's out the door by the end of October. (/me crosses his fingers for luck.)
That said, I'm hoping for November some time. Of course, all of us developer types are optimists... Wink
Blue LEDs are evil.
brother303
PostPosted: Fri Sep 23, 2011 8:59 am    Post subject: Reply with quote  Mark this post and the followings unread
I´m not in a hurry,no problem here.
Are there some leftovers for the next MB808 run or are all boards/kits spoken for? Maybe I should jump on this train...
Kind regards
Greg
Dougster
PostPosted: Fri Sep 23, 2011 10:31 am    Post subject: Reply with quote  Mark this post and the followings unread
All of the third batch kits are spoken for. I'll be making a fourth batch of kits, since I had to buy parts for 250 kits. (For example, the minimum order quantity for the colored switches was 1000, and each kit takes four.)
If the fourth batch is anything like the third, I'll have a bunch of people on the waiting list, but only about a quarter of them will actually buy...
Blue LEDs are evil.
inlifeindeath
PostPosted: Fri Sep 23, 2011 12:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
What's the price per kit if I may ask?
Peake
PostPosted: Fri Sep 23, 2011 1:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
Can't wait to buy mine Cool
Dougster
PostPosted: Fri Sep 23, 2011 1:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
Roughly speaking (it depends on the cost of pcb manufacturing, and I won't find out the final cost until I actually place the order) the kit from me is about $200, and you'll need about $150 of parts from Mouser or likesuchas, plus a toroid for the power supply. The one I use is about $30 from Digikey. That will get you a fully functioning 808 sound generator with MIDIbox sequencer.
After that, you'll need some kind of case. Most of the guys have been getting a Hammond 1456RL1 and then having Front Panel Express cut the holes and either having the top silkscreened or printing an overlay to stick on...
Blue LEDs are evil.
n.d
PostPosted: Thu Dec 22, 2011 12:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
Can I trigger the 808 sounds from a DR110?
Dougster
PostPosted: Thu Dec 22, 2011 5:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
Anybody have a DR110 I can borrow? Wink
I'm really slow, but I *will* get it back to you eventually...
Blue LEDs are evil.
Sebo
PostPosted: Fri Dec 23, 2011 1:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
The 808 is active high, and the DR-110 is active low, so you have to invert the signal. You can use a transistor for every trigger or a couple of 4069 (each will invert 6 triggers).
Also the DR-110 have a trigger output (is activated with the accent) that you can use as is, without any mod.
Sebo
My Music:
www.cosaquitosenglobo.com.ar
rosch
PostPosted: Sat Dec 24, 2011 1:25 am    Post subject: Reply with quote  Mark this post and the followings unread
doug,
that's nice to hear about another run of MB808 in the future. i'd be in if there's still room on your list. should i email / MB-pm you about it?
Dougster
PostPosted: Sat Dec 24, 2011 8:50 am    Post subject: Reply with quote  Mark this post and the followings unread
Email is best. Doug (at) midibox addict (dot) com
Regards,
Doug
Blue LEDs are evil.
