SubG (deactivated)
Posted: Fri Sep 09, 2011 11:48 pm Post subject:
| Sebo wrote: | Hi:
Here are some pictures of my TR-808 clone, also the TR-9090 (909 clone) and some other nice gear (DIY and non-DIY). |
Nice! |
wizardsofzen
Posted: Sat Sep 10, 2011 6:53 am Post subject:
808 mods |
i know im blind, is there a page that has the mods collected to add the extra control to Eric Archers layouts? _________________ use your favorite search engine to find more from - Wizards of Zen |
Joined: May 16, 2005 Posts: 8902 Location: Birmingham, England, UK
Posted: Sat Sep 10, 2011 8:05 am Post subject:
| Sebo wrote: |
That's a nice bit of DIY 909 going on there! Does it sound anything like the original? _________________ ACHTUNG!
brother303
Joined: Nov 02, 2010 Posts: 139 Location: ruhr-area/germany
Posted: Sat Sep 10, 2011 9:22 am Post subject:
Hi Sebo,
awesome! The 8080 is absolutely awesome!!!
Exactly what I need next to my 9090...
 _________________ Best regards
Greg |
Sebo
decaying.sine
Joined: Aug 31, 2009 Posts: 92 Location: New Haven, CT, USA
Posted: Mon Sep 12, 2011 4:05 am Post subject:
| I'd be in for single voice PCBs too! |
corex
Posted: Tue Sep 13, 2011 10:25 am Post subject:
...and my axe!
I mean, I would also love to buy single-voice PCBs. |
Dougster
Joined: Sep 20, 2005 Posts: 272 Location: Tucson, AZ, USA
Posted: Mon Sep 19, 2011 10:59 am Post subject:
OK, I finished the three voice only boards (four voices per board), now it's time to lay out the individual voice boards. Do you guys care what the form factor is? In other words, should I just make the boards as small as possible with mounting holes on the corners, or should I try to make them fit a particular bracket or front panel? _________________ Once you start down the modular path, forever will it dominate your destiny!
Every DIY person should own a copy of Electronotes: http://electronotes.netfirms.com
Blue LEDs are evil. |
emdot_ambient
Joined: Nov 22, 2009 Posts: 669 Location: Frederick, MD
Posted: Mon Sep 19, 2011 2:11 pm Post subject:
I would suggest making them as small as possible with Euro formats in mind (possibly with pot and jack pads for PCB mount components), but also with mounting holes so that those of us who don't like to use panel mounted pots can mount them on a bracket.
For most universal appeal, probably good to allow several types of power connectors...what voltages do these run on? I'm sure you'll get a mix of people using -/+12V and -/+15V on their systems. _________________ Looking for a certain ratio since 1978 |
Dougster
Posted: Mon Sep 19, 2011 2:59 pm Post subject:
I've always run these things at 15V. I have a bench power supply; I'll test at 12V and see how that sounds...
EDIT: P.S. I don't have any Euro stuff, but I'll check out the format specs. (I have mainly MOTM, with a bit of Blacet.) _________________ Once you start down the modular path, forever will it dominate your destiny!
Paradigm X
Joined: Feb 15, 2011 Posts: 252 Location: Null and void
Posted: Mon Sep 19, 2011 4:07 pm Post subject:
| Dougster wrote: | | OK, I finished the three voice only boards (four voices per board), now it's time to lay out the individual voice boards. Do you guys care what the form factor is? In other words, should I just make the boards as small as possible with mounting holes on the corners, or should I try to make them fit a particular bracket or front panel? |
Awesome !
What are on each board ?
Cheers!
Ben |
Dougster
Posted: Mon Sep 19, 2011 4:49 pm Post subject:
| Paradigm X wrote: | | What are on each board ? |
There are four voices on each board. I nicknamed the boards "white", "pink" and "schmitt" because most of the voices depend upon one of those sound generators. (Only the kick and rimshot don't.)
The first board has:
Kick
White noise generator
Snare (uses white noise)
Maraca (uses white noise)
Clap (uses white noise)
Second board has:
Pink noise generator
Low Tom (uses pink noise)
Mid Tom (uses pink noise)
High Tom (uses pink noise)
Rimshot/Clave
Third board has:
Schmitt oscillators
Cowbell (uses Schmitt)
Cymbal (uses Schmitt)
Open Hat (uses Schmitt)
Closed Hat (uses Schmitt)
I also thought about having two boards, one with the noise generator and the six voices that depend on it and a second board with the schmitt circuit and the four voices that depend on it plus the kick and rimshot:
Snare
Low Tom
Mid Tom
High Tom
Maraca
Clap
Kick
Rimshot/Clave
Cowbell
Cymbal
Open Hat
Closed Hat
Those seemed to be the two most logical combinations. _________________ Once you start down the modular path, forever will it dominate your destiny!
Paradigm X
Posted: Mon Sep 19, 2011 5:02 pm Post subject:
Amazing
Any idea when these might be ready for purchase (sorry, very early days i know). Boards 1 and 3 for me for a start, then 2.
Cheers |
Dougster
Posted: Mon Sep 19, 2011 5:36 pm Post subject:
Can't give you a firm date at the moment. I'll be out of town on business until October 15. The prototype boards should be here when I get back, so I'll build them and make sure there are no problems. There shouldn't be any problems, since these are the same circuits I use in the MB-808, but I may have made a mistake somewhere, so I'll build prototypes just to be sure. Once I have built a good prototype, I'll have a stack of pcbs made and then let everyone know they're available...
The full MB-808 is the highest priority project in my queue right now and I don't plan to ship anything else until this batch of MB-808 kits is out the door. Heck, I haven't built anything for myself for over two years...  _________________ Once you start down the modular path, forever will it dominate your destiny!
SubG (deactivated)
Posted: Mon Sep 19, 2011 9:18 pm Post subject:
Paradigm X
Posted: Tue Sep 20, 2011 1:25 am Post subject:
| Dougster wrote: | Can't give you a firm date at the moment. I'll be out of town on business until October 15. The prototype boards should be here when I get back, so I'll build them and make sure there are no problems. There shouldn't be any problems, since these are the same circuits I use in the MB-808, but I may have made a mistake somewhere, so I'll build prototypes just to be sure. Once I have built a good prototype, I'll have a stack of pcbs made and then let everyone know they're available...
The full MB-808 is the highest priority project in my queue right now and I don't plan to ship anything else until this batch of MB-808 kits is out the door. Heck, I haven't built anything for myself for over two years...  |
That's awesome gives me a chance to save up a bit. Many thanks  |
brother303
Posted: Tue Sep 20, 2011 9:51 am Post subject:
Hi Doug,
| Dougster wrote: |
I also thought about having two boards, one with the noise generator and the six voices that depend on it and a second board with the schmitt circuit and the four voices that depend on it plus the kick and rimshot...
That´s what I like best. Two boards would be cool!
Greg |
emdot_ambient
Dougster
Posted: Wed Sep 21, 2011 10:08 am Post subject:
Thought I should publish some of the details of the multi-voice boards in case anyone has heartburn about the way I'm doing this...
There is no power supply on the voice boards, that is, no regulators, so a separate +/-15V power source is required. (I have not tested with +/-12V, so I don't know how that will work.)
There are three headers for each voice, a three pin trigger and accent input header, a two pin sound output header, and a header for controls (Potentiometers and switches.)
There is no LED driver. I was thinking that could be included on whatever sends the trigger pulse. Is that a problem?
The individual voice boards will be similar, but I'll look at using pcb mount potentiometers for panel mounting.
(Should I start a new thread for all of this, or should I continue to hijack this one?) _________________ Once you start down the modular path, forever will it dominate your destiny!
brother303
Posted: Wed Sep 21, 2011 11:26 am Post subject:
Hi Doug,
sounds good to me.
Greg |
emdot_ambient
Posted: Wed Sep 21, 2011 12:03 pm Post subject:
The way you're doing it sounds fine to me, too.
It's DIY. If people want/need an LED driver for the inputs, they can always add them, or do as you suggest and just use the trigger source.
What kind of trigger do these need, BTW? _________________ Looking for a certain ratio since 1978 |
Paradigm X
Posted: Wed Sep 21, 2011 12:15 pm Post subject:
Agreed, however you see fit  |
Joined: Jan 07, 2009 Posts: 588 Location: Scottish Borders
Audio files: 69
Posted: Wed Sep 21, 2011 2:25 pm Post subject:
I like the idea of 2 boards as well for my new diy drum sound module .
Maybe a new thread just to clarify who wants a 2 pcb whole sound set or individual pcb voices , would be a good idea
Thanks for spending time on this Doug , your a star
Dave _________________ www.myspace.com/skrogproductions |
SubG (deactivated)
Posted: Wed Sep 21, 2011 9:26 pm Post subject:
no psu on board, +/- 15v
PERFECT ,can't wait to order |
