  bingsatellites Mostly Ambient
lease Help. Broadwave Arp Odyssey Diy part question
Page 1 of 1 [5 Posts]
citric acid
PostPosted: Thu Aug 18, 2011 9:01 am    Post subject: lease Help. Broadwave Arp Odyssey Diy part question Reply with quote  Mark this post and the followings unread
hope someone can help me.
i have no 2N5910 and they are hard to get here in germany.
I saw in the Bom that i also can use an 2n3906 . but i can´t find an information in the net how to solder them in . I mean in witch direction. can someone help me please!
Thanks
http://soundcloud.com/citric-acid-303
Level5
PostPosted: Fri Aug 19, 2011 1:23 am    Post subject: Reply with quote  Mark this post and the followings unread
When you look from Top at the flat side, the Pin's from the 2N3906 are E-B-C (from left to right)
citric acid
PostPosted: Fri Aug 19, 2011 9:14 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks, that helps 50% . do you know in witch direction i have to solder them on the pcb? flat side down or up. the 3 pins on the pcb are not clearly named. i mean i know e-b-c but i can´t find witch solder point is e-b-c ... sorry
Level5
PostPosted: Sat Aug 20, 2011 1:11 am    Post subject: Reply with quote  Mark this post and the followings unread
I compared the Layout with the Arp-schematics:
the 2N5910 has C-B-E, flat side down, then the 2N3906 must have the flat side up.
citric acid
PostPosted: Sat Aug 20, 2011 9:57 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks thanks.... you made my day and saved my module...
Rolling Eyes
