  bingsatellites Mostly Ambient
DIY PSU for 9v machines
Page 1 of 1 [6 Posts]
themanthatwasused
PostPosted: Sun Sep 04, 2011 1:24 am    Post subject:  DIY PSU for 9v machines
Subject description: Please help me on a recommendation for a simple PSU for 9v handmade instruments
Hi, im still a relative newbie in this forum and on DIY instruments.
I am currently using two oscillators that my friend help me build.
As seen above, one is a Hex Schmitt trigger chip, and a NAND chip oscillator.
I want to make two more or another device plus my Roland TR626, which will all be powered by 9v. If I want to put them in one case, how do I make a simple and effective PSU for the 4 machines that are 9V.
I have built and bent simple objects before and can handle basic soldering so I can handle basic circuits for this.
Can anybody here recommend a simple way to do this?
Has anyone attempted the same project?
Thanks in advance.
Mongo1
PostPosted: Sun Sep 04, 2011 6:15 am    Post subject: Reply with quote  Mark this post and the followings unread
One possible solution is the small bear electronics 9v ps kit - Here's a link
http://www.smallbearelec.com/Projects/SmWart/SmWart.htm
Good luck
Gary
themanthatwasused
PostPosted: Sun Sep 04, 2011 6:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
Good luck
Gary
Wow, looks simple enough for a novice like me.
Thank you so much sir!
dylar
PostPosted: Sat Oct 15, 2011 10:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
If it's just a DC 9V power supply you want, the easiest way is to grab a wall wart and solder the wires to a stripboard. Just create a bus.
There are plenty of designs for reducing any possible ripple in the signal if you want to get all hi-fi about it. But in my experience running several pedals off a bussed wall wart is a perfectly fine solution (in short, you're just making a daisy chain from a wall wart).
Building a power supply from scratch isn't really worth it (IMO) unless you need some sort of specialized supply, like a bipolar one.
dylar
PostPosted: Sat Oct 15, 2011 11:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
also, if you want to filter the power supply but don't want to mess with wiring a transformer, couldn't you just build the filtering part of the Small Wart and solder the secondary of a wall wart to where the secondary of the transformer would go? Having a bit of extra filtering isn't going to hurt anything, right?
corex
PostPosted: Mon Oct 17, 2011 1:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
Using a wall-wart directly is easy, but I find that it's not much more difficult to use an LM7809 and regulate it (use a 12V wall wart, say.)
If you want to get fancy with regulation and filtering, the MFOS bipolar supplies are a good way to go: http://www.musicfromouterspace.com/analogsynth_new/WALLWARTSUPPLY/WALLWARTSUPPLY.php
