Lunetta Beautifier
Page 1 of 1 [5 Posts]
Inventor
Audio files: 256
PostPosted: Sun Sep 04, 2011 8:45 am    Post subject: Lunetta Beautifier
Subject description: ChucK post-processor for Lunettas
I made a ChucK program that removes the harsh square wave sounds from Lunetta audio outputs, or minimizes them anyway. Listen to the attached audio sample, first there is a Lunetta sequence then a brief pause and the same sequence processed by the ChucK program.
It sounds a bit bubbly and sine wavy, which is OK I guess. Some people prefer the natural digital sounds, but I kind of like the processed one better. Of course there are many ways to do such "beautification", and maybe I'll have another try at it based on comments posted here.
The algorithm is simple: take an fft, find the strongest harmonic, attenuate neighboring harmonics by exponentially increasing amounts according to their distance from the strongest harmonic, then take an ifft to get the final audio.
ta-da! beautification. Enjoy!
Les
Lunetta Beautifier.ck
the chuck file
 Filename:  Lunetta Beautifier.ck
 Filesize:  596 Bytes
 Downloaded:  62 Time(s)
Lunetta Beautifier.mp3
the audio sample
 Filename:  Lunetta Beautifier.mp3
 Filesize:  526.23 KB
 Downloaded:  168 Time(s)
Sonic
PostPosted: Sun Sep 04, 2011 10:11 am    Post subject: Reply with quote  Mark this post and the followings unread
Nice. I like the audio both with and without the beautifier. Do you plan to build a hardware version?
Inventor
Audio files: 256
PostPosted: Sun Sep 04, 2011 11:33 am    Post subject: Reply with quote  Mark this post and the followings unread
A hardware version of this algorithm would be quite complex, and what little time I have spent trying to imagine another more implementable hardware version has not been fruitful. I will give it some more thought, because that would be a really nice thing to have - and you asked!
Les
Audio files: 29
PostPosted: Thu Sep 08, 2011 5:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
I would be interested in a hardware version too. Also, the demo seemed to either be on or off. Could it be applied with a pot like a filter? If not, then maybe I could just split the sound first, modify one of the splits, and then use a pot to mix them back together.
Inventor
Audio files: 256
PostPosted: Fri Sep 09, 2011 12:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
Cyno, yes there are a couple of parameters that can be varied like a potentiometer. I'll pull them to the top and name them as variables if I get time.
Les
Niio1
