emil
Posted: Sun Sep 25, 2011 11:59 am Post subject:
curvetable issue |
Dear list,
I have an issue with the curvetable. Hopefully someone can give me hint.
I'm trying to set up a curve with more then 32 timeN / curvaturenN / valueN values.
Everything works fine for less then 32 values, but when I put more then 32, chuck will instantly crash.
Not sure if this is a bug, some undocumented limitations of the curve or I'm making something wrong.
Here is a example:
[/code]
CurveTable c;
// coeffs are all FLOATS, specifying proportional times, values, and curvature:
// [time0, value0, curvature to next, time1, value1, curvature,..
// timeN-1, valueN-1, curvaturen-1, timeN, valueN]
float cur, val;
0.1=>cur=>val;
// set
0.129, val, cur, 0.13, val, cur, 0.131, val, cur, 0.132, val, cur, 0.133, val, cur, 0.134, val, cur, 0.135, val, cur, 0.136, val, cur,
0.137, val, cur, 0.138, val, cur, 0.139, val, cur, 0.14, val, cur, 0.141, val, cur, 0.142, val, cur, 0.143, val, cur, 0.144, val, cur,
0.145, val, cur, 0.146, val, cur, 0.147, val, cur, 0.148, val, cur, 0.149, val, cur, 0.15, val, cur, 0.151, val, cur, 0.152, val, cur,
0.153, val, cur, 0.154, val, cur, 0.155, val, cur, 0.156, val, cur, 0.157, val, cur, 0.158, val, cur, 0.159, val, cur, 0.16, val, cur, // at this point the curve works good
0.161, val, cur, 0.162, val, cur, 0.163, val, cur, 0.164, val, cur, 0.165, val, cur, 0.166, val, cur, 0.167, val, cur, 0.168, val, cur, //if we include more point we get a crash
0.169, val, cur, 0.171, val, cur, 0.172, val, cur, 0.173, val, cur, 0.174, val, cur, 0.175, val, cur, 0.176, val, cur, 0.177, val, cur,
0.178, val, cur, 0.179, val, cur, 0.180, val, cur, 0.180, val, cur, 0.181, val, cur, 0.182, val, cur, 0.183, val, cur, 0.184, val, cur,
0.185, val, cur, 0.186, val, cur, 0.187, val, cur, 0.188, val, cur, 0.189, val, cur, 0.190, val, cur, 0.191, val, cur, 0.192, val
] => c.coefs;
// create an envelope to scan through the table values
Envelope e => blackhole;
e.duration(10000::ms);
0. => e.value;
e.keyOn(); //ramp to 1 in 10 seconds
// patch
Phasor p => c => dac;
// set
440. => p.freq;
// ready
while (true)
// print
<<< e.value(), c.lookup(e.value()) >>>;
// end
if(e.value() == 1.) break;
// advance time
10::ms => now;
[/code] |
