curvetable issue
Page 1 of 1 [4 Posts]
emil
PostPosted: Sun Sep 25, 2011 11:59 am    Post subject: curvetable issue Reply with quote  Mark this post and the followings unread
Dear list,
I have an issue with the curvetable. Hopefully someone can give me hint.
I'm trying to set up a curve with more then 32 timeN / curvaturenN / valueN values.
Everything works fine for less then 32 values, but when I put more then 32, chuck will instantly crash.
Not sure if this is a bug, some undocumented limitations of the curve or I'm making something wrong.
Here is a example:
[/code]
CurveTable c;
// coeffs are all FLOATS, specifying proportional times, values, and curvature:
// [time0, value0, curvature to next, time1, value1, curvature,..
// timeN-1, valueN-1, curvaturen-1, timeN, valueN]
float cur, val;
0.1=>cur=>val;
// set
0.129, val, cur, 0.13, val, cur, 0.131, val, cur, 0.132, val, cur, 0.133, val, cur, 0.134, val, cur, 0.135, val, cur, 0.136, val, cur,
0.137, val, cur, 0.138, val, cur, 0.139, val, cur, 0.14, val, cur, 0.141, val, cur, 0.142, val, cur, 0.143, val, cur, 0.144, val, cur,
0.145, val, cur, 0.146, val, cur, 0.147, val, cur, 0.148, val, cur, 0.149, val, cur, 0.15, val, cur, 0.151, val, cur, 0.152, val, cur,
0.153, val, cur, 0.154, val, cur, 0.155, val, cur, 0.156, val, cur, 0.157, val, cur, 0.158, val, cur, 0.159, val, cur, 0.16, val, cur, // at this point the curve works good
0.161, val, cur, 0.162, val, cur, 0.163, val, cur, 0.164, val, cur, 0.165, val, cur, 0.166, val, cur, 0.167, val, cur, 0.168, val, cur, //if we include more point we get a crash
0.169, val, cur, 0.171, val, cur, 0.172, val, cur, 0.173, val, cur, 0.174, val, cur, 0.175, val, cur, 0.176, val, cur, 0.177, val, cur,
0.178, val, cur, 0.179, val, cur, 0.180, val, cur, 0.180, val, cur, 0.181, val, cur, 0.182, val, cur, 0.183, val, cur, 0.184, val, cur,
0.185, val, cur, 0.186, val, cur, 0.187, val, cur, 0.188, val, cur, 0.189, val, cur, 0.190, val, cur, 0.191, val, cur, 0.192, val
] => c.coefs;
// create an envelope to scan through the table values
Envelope e => blackhole;
e.duration(10000::ms);
0. => e.value;
e.keyOn(); //ramp to 1 in 10 seconds
// patch
Phasor p => c => dac;
// set
440. => p.freq;
// ready
while (true)
// print
<<< e.value(), c.lookup(e.value()) >>>;
// end
if(e.value() == 1.) break;
// advance time
10::ms => now;
[/code]
GrandJu
PostPosted: Wed Sep 28, 2011 8:27 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi emil,
I don't know how curvetable works. That's why I just took a look at the manual.
page 175 section GenX: it is written:"Currently coefficients
past the 100th are ignored."
I think your problem may be linked to that...
Ju
emil
PostPosted: Thu Sep 29, 2011 1:46 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Ju,
thanks for the input.
Your right but in this case whe are only using 63 coefficients. The curve will crash chuck also with 33 coefficients.
Emil
GrandJu
PostPosted: Wed Oct 12, 2011 4:18 am    Post subject: Reply with quote  Mark this post and the followings unread
ok, I certainly mistake about number of parameters and number of coefficient...
Niio1
