Polymoog resonator
Page 1 of 1 [8 Posts]
chok
PostPosted: Thu Sep 29, 2011 2:29 am    Post subject: Polymoog resonator
Subject description: small question before construction
Hello all
For my intended bigger enjoyment, I am going to build this magnificent clone and to size correctly the supply, I would like to know, by those who would have already built it, how much consumes this filter on both positive and negative lines.
Thank you very much
Wink Pascal
chok
PostPosted: Fri Sep 30, 2011 1:25 am    Post subject: Reply with quote  Mark this post and the followings unread
cry
It is not just, I am a poor small forgotten chick Confused
Audio files: 116
G2 patch files: 317
PostPosted: Fri Sep 30, 2011 4:36 am    Post subject: Reply with quote  Mark this post and the followings unread
Ce n'est pas juste ... indeed ... if I knew I'd tell you tho ... may the bump help!
thermionicjunky
PostPosted: Fri Sep 30, 2011 7:17 am    Post subject: Reply with quote  Mark this post and the followings unread
Grove Audio sells a version of this and they list a current draw of 25mA from each rail.
jumunius
PostPosted: Fri Sep 30, 2011 9:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm sorry to say it, but don't hold your breath for help in JH's forum. I think everyone who has built his boards is off playing with their gear and not replying to questions. It is very frustrating.
While I haven't yet built mine yet, modularsynthesis.com's Polymoog Resonators page reports the following:
Power consumption: 21 mA +15, 20 mA -15
jumunius
PostPosted: Fri Sep 30, 2011 9:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
PS. So pretty much what thermionicjunky said. And there I was bitching about how unresponsive this board is. Embarassed
jhaible
PostPosted: Sun Oct 02, 2011 3:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
It might help posting into an already existing thread (there's one for each project!), instead of starting a new one. Why? Because normally everybody who posted into that thread previously, will automatically get an email when a new post is made. But if you start a new thread, you're waiting until stumbles across it ...
JH.
jumunius
PostPosted: Sun Oct 02, 2011 7:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
JH.
Agreed. To be fair I tried posting to an existing thread with both the SOST Flanger and the Solina Chorus, had no luck in either. (The Solina I figured out on my own, the Flanger I have yet to resolve.) And then I tried writing a new SOST Flanger post in case that worked better, which it hasn't.
Generally speaking I find people more responsive on your boards to parts and planning questions than troubleshooting questions. I don't know maybe it's just the complexity of the projects for the average DIY'er that stops a lot of people from answering, and then others are advanced enough that they are tired of figuring out which bad solder lead to a problem build. Or maybe electro-music is in a lull.
Mind you now I've hijacked the OP's thread with my whining.
