CD4031 tap looper...
Page 3 of 4 [86 Posts]
cyclic
PostPosted: Thu Dec 19, 2019 6:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
yep, I'm pretty sure I got it then!
If I have time to PCBify something for the original tap-looper I'll
- check here with schematics etc so its checked over
- make sure I make it small enough to either get 2 on a 10x7 or make it fairly easy to chain them together.
I don;t think I'll be doing that 63step cv sequencer even though I understand it now and reckon its a pretty inspired idea, but by doing the above it should make it easier to use anything I do for it.
dadinfinitum
PostPosted: Sun Sep 13, 2020 7:29 am    Post subject: Reply with quote  Mark this post and the followings unread
I have tried to get both PHOBoS's simpler version and this version, but I can't get either of them to work. I've double and triple checked my circuit on the breadboard!
dk
PostPosted: Sun Sep 13, 2020 7:49 am    Post subject: Reply with quote  Mark this post and the followings unread
How are you testing it? Do you have a LED strapped across the output to see what's coming out?
It's a 64 step sequence, so if you use a slow clock, and can take a while for the chip to spit out what you've input.
dadinfinitum
PostPosted: Sun Sep 13, 2020 9:02 am    Post subject: Reply with quote  Mark this post and the followings unread
I have the output as a gate for a 40106 osc. Also using a 40106 osc (albeit a slower one) for the clock. I have LEDs on both of those. Also using a multimeter on both the data in and the data out.
dk
PostPosted: Wed Sep 16, 2020 4:08 am    Post subject: Reply with quote  Mark this post and the followings unread
How about when you have the output disconnected and you just hang a LED and dropping resistor off of it?
These circuits are really simple, so it's likely that either you have a big error somewhere that doesn't want to be seen or you have a bad chip.
For what it's worth, I built 2 of the more complex versions and they work fine. I've attached my stripboard layout, in case it helps. You can ditch the voltage regulator and associated parts if you don't need them, and directly attach your voltage to the trace BELOW gnd. Also, beware on the right side than I have 2 jumpers sharing the same hole (not very elegant, but whatever).
4031 stripboard
 Filesize:  141.04 KB
 Viewed:  419 Time(s)
dadinfinitum
PostPosted: Wed Sep 16, 2020 5:06 am    Post subject: Reply with quote  Mark this post and the followings unread
Yeah, it seemed pretty simple, which is why I've been surprised it hasn't worked. I'll see if I can emulate your stripboard.
dadinfinitum
PostPosted: Wed Sep 16, 2020 7:09 am    Post subject: Reply with quote  Mark this post and the followings unread
So, still no luck. The LED at the end doesn't light up, and the oscillator that is using the output as a gate doesn't activate. Using my scope on the output, it looks constantly high? Which is really weird.
 Filesize:  3.1 MB
 Viewed:  371 Time(s)
 Filesize:  2.54 MB
 Viewed:  370 Time(s)
dk
PostPosted: Wed Sep 16, 2020 7:27 am    Post subject: Reply with quote  Mark this post and the followings unread
Hard to tell from the pic, but it looks like you haven't grounded the chip? Pin 8 should go to ground, while pin6 should connect with pin 10 and your output..
EDIT: I was under the impression that between pins 6 and 8 there was a loop, but that's probably just the picture cutting it that way.
dadinfinitum
PostPosted: Wed Sep 16, 2020 8:00 am    Post subject: Reply with quote  Mark this post and the followings unread
Sorry, that picture was mostly to identify the chip. Here's a better picture (pin 8 is grounded via row 27, and pin 10 to pin 6 via row 41).
 Filesize:  2.68 MB
 Viewed:  363 Time(s)
Audio files: 705
PostPosted: Wed Sep 16, 2020 11:07 am    Post subject: Reply with quote  Mark this post and the followings unread
From what I can tell that looks ok.
You could try the bare minimum to see if the chip does anything at all:
pin1: GND
pin2: fast (KHz) oscillator input
pin3: NC
pin4: NC
pin5: NC
pin6: output
pin7: NC
pin8: GND
pin9: NC
pin10: GND
pin11: NC
pin12: NC
pin13: NC
pin14: NC
pin15: slow oscillator input
pin16: V+
If the CLK (2) frequency is fast enough the output (6) should pretty much follow the oscillator on the input (15).
Also move the chip to another part of the breadboard.
dadinfinitum
PostPosted: Wed Sep 16, 2020 5:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
Good news: it works. Now to figure out what's wrong with the circuit. I even read through the datasheet and the CMOS cookbook to try and troubleshoot/test other configurations.
dadinfinitum
PostPosted: Thu Sep 17, 2020 12:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
I got the circuit to work!
The only issue: it starts high, so I have to hold erase through a cycle to clear it. I tried pulldowns on the write and erase switches, but nothing. Thoughts on that?
Audio files: 705
PostPosted: Thu Sep 17, 2020 1:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
cheers good to hear it works
shiftregisters and a lot of other CMOS chips often start up in a random state so unless it has a reset input there isn't much you can do about it.
I guess you could add an extra switch which enables a fast CLK and pulls the data input low at the same time
dadinfinitum
PostPosted: Thu Sep 17, 2020 4:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
If an easy solution is just "start in erase mode," then that's fine. (I'm using a traditional toggle switch for erase, and a keyboard switch for tapping)
dk
PostPosted: Sat Sep 19, 2020 5:23 am    Post subject: Reply with quote  Mark this post and the followings unread
Glad to see you got it working! I have two in my rig, one of which starts up empty, the other full. It's a bother, but not enough for me to fix it Laughing
zaphod betamax
PostPosted: Fri Nov 27, 2020 8:32 am    Post subject: Reply with quote  Mark this post and the followings unread
Don't forget about the CD4517.
Available at digikey.ca and other places
Estebandito
PostPosted: Sun Dec 20, 2020 5:38 am    Post subject: Just wanted to share my version of the tap looper Reply with quote  Mark this post and the followings unread
My version of the tap looper. It is pretty much the most basic version, with an external clock input as well as an inbuilt clock (with cap switch, and pulse/gate switch). Outputs are Q, inverted Q. Also there are two outputs from the 7-segment display drivers and one where I send those outputs through a NAND gate.
 Filesize:  3.22 MB
 Viewed:  138 Time(s)
trim.0FC2BD09-614E-4ABB-ACEA-776483BC81C5.MOV
 Filename:  trim.0FC2BD09-614E-4ABB-ACEA-776483BC81C5.MOV
 Filesize:  52.12 MB
 Downloaded:  338 Time(s)
Audio files: 705
PostPosted: Sun Dec 20, 2020 7:16 am    Post subject: Reply with quote  Mark this post and the followings unread
veyr cool build Very Happy
what did you use to drive the displays ?
Estebandito
PostPosted: Sun Dec 20, 2020 8:35 am    Post subject: Reply with quote  Mark this post and the followings unread
Two 4026’s. They are meant to drive common cathode displays but I only had common anode ones, so each display output is hooked up to a transistor with the collector connected to the display and the emitter to gnd. It works but I don’t recommend it unless you don’t mind lots of additional soldering. Razz
I forgot to mention I also used two 4017’s to limit the count to 63 (not 64 as the counter starts at 00). The photo shows the 4026’s, a 4093 (used for the clock and the erase button), and two 4017’s. So apart from the 4093 this is just to make the counter work, I hadn’t even put the 4031 in there yet.
 Filesize:  4.27 MB
 Viewed:  138 Time(s)
Audio files: 705
PostPosted: Mon Dec 21, 2020 6:12 am    Post subject: Reply with quote  Mark this post and the followings unread
ah, a combined counter+display driver. Main reason I asked is because it can be tricky to control more than 1 display
with some logic chips, at least from a seperate counter. It's a nice idea those displays.
Estebandito
PostPosted: Mon Dec 21, 2020 8:23 am    Post subject: Reply with quote  Mark this post and the followings unread
This is my first use of 7-digit displays and drivers and they seem to be working fine. The only issue with this module is that the 4031 output sometimes goes high and stays high until the power has been switched off for a while. As far as I can tell this happens when pushing the write data button when the output is high.
dk
PostPosted: Wed Apr 14, 2021 6:55 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm finally getting around to de-bouncing my switches and was thinking of adding a data input (since I'll have left over 40106's anyway).
Does anyone see anything wrong with this, before I tear into the module? ( besides not using a logic gate for the switch, of course Very Happy )
Edit: Sorry, I should have written that my build is PHOBoS' deluxe version.
 Filesize:  35.09 KB
 Viewed:  122 Time(s)
dk
PostPosted: Thu May 20, 2021 5:30 am    Post subject: Reply with quote  Mark this post and the followings unread
Just an update to the previous post. I updated it so that the switch is AND gated with the data input and also added the switch debouncing circuit. I haven't breadboarded it yet, but theoretically it should work?
 Filesize:  80.24 KB
 Viewed:  119 Time(s)
Audio files: 705
PostPosted: Thu May 20, 2021 7:44 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm not sure if that does what you want it to do. When the data enable switch is connected to GND, DIN1 is low and DIN2 is high,
which doesn't do anything so that would be ok I assume. Now if the data enable switch is connected to V+ (or not connected,
doesn't matter) and your data input is high then DIN1 is high and DIN2 is low. Which is the equivalent of pressing both the write
and erase button at the same time. I'll have to check the datasheet again to see what that does but I would think that you either
want to write a bit or erase a bit, not do both at the same time. If I ignore the CD4031 and just look at what would happen with
the output then U2c would be low, U2b would be high and as a result U2d and U2a would be low.
dk
PostPosted: Thu May 20, 2021 2:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
Oh, you're right!
The momentary at the top is just the write switch. I was hoping (with the now-obviously incorrect bottom section) to be able to enable and disable the data input without interfering with the buttons. Do you have any ideas how to accomplish this? My first thought was to use a switch (4066), but I was trying to skimp on using an extra chip .... or perhaps I need to?
