Random Accent/Beat
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Sun Jan 30, 2005 12:19 am    Post subject: Random Accent/Beat Reply with quote  Mark this post and the followings unread
Here is a simple idea, ever end up with a spare row of triggers? With just a RndTrig module you can create a random grace beat. Put the new beats at selected points off the main beat and run the trigger out to the input RndTrig module whose output goes to the trigger in of the sequencer. The sequencer trigger in allows for convenient serial sequencer connections but simply mixes the input with the internal trigger pulses.
The example patch adds a LevAmp to reduce the level of the extra trigger pulses and a S&H to recover the different levels. Now a trigger at the same point on both rows accents that beat randomly.
The probablity control is modulated to provide extra variation over time.
RndAccent.pch2
demo for random trigger/accent idea
 Filename:  RndAccent.pch2
 Filesize:  3.63 KB
 Downloaded:  1575 Time(s)
