Dual Gated Slew oddities
Page 1 of 1 [3 Posts]
marfoski
PostPosted: Tue Oct 25, 2011 9:31 am    Post subject: Dual Gated Slew oddities Reply with quote  Mark this post and the followings unread
Hi Yves and all,
I just finished to build a dual gated slew that works fairly well.
I've noticed a few oddities, tho:
1. In linear mode the slew rate is much faster than in log mode, expecially when going down on the keyboard;
2. In log mode, when in UP or DOWN position, there is a small lag in the opposite direction.
Nothing tragic but I would like to know if it's a normal behavior for this module.
Thank you for your splendid work and support
Marco
yusynth
PostPosted: Tue Oct 25, 2011 12:51 pm    Post subject: Re: Dual Gated Slew oddities Reply with quote  Mark this post and the followings unread
marfoski wrote:
Hi Yves and all,
Yes that's perfectly normal because in linear mode the slope remains constant during the charging of the capacitor and therefore it reaches the complete load very quickly compared to the log mode where the slope keeps decreasing while the cap gets loaded.
Once again it's normal it is due to the fact that the diodes are silicon diodes, this small lag could be reduced by using euther germanium or shottky diodes.
Yves
marfoski
PostPosted: Tue Oct 25, 2011 9:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thank you Yves,
now I can carry on to next module in the peace of my mind Very Happy
