small hacked piano
Page 1 of 1 [4 Posts]
mako
PostPosted: Tue Nov 01, 2011 1:42 pm    Post subject: small hacked piano
Subject description: i don't know if you can call this circuit bending but i think you can
hi there,
I found a little piano and I wanted to opened it up and see what i could change...
but then i found out there was only this ugly black blob blocking the entire circuit Sad although there was something I could do inside...
And now my question: I showed it to my friend and he said that i could link an oscillator to use a function of the piano that played notes on itself in a certain pattern. So now i made a very fast or slow( i used an LDR) autonomously playing piano!
here is the video: http://www.youtube.com/watch?v=Xrp2mABohm8
please give your comments or tips Smile
Mongo1
PostPosted: Wed Nov 02, 2011 12:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
Have you considered bending that piano with a claw hammer? Laughing
Just kidding - looks like you're having fun!
Gary
mako
PostPosted: Wed Nov 02, 2011 1:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
indeed i am having fun Smile
i'll some other stuff and see if i find interesting noises...
and else i'll solder something like this in it and put it back together
Audio files: 253
PostPosted: Thu Nov 03, 2011 4:11 am    Post subject: Reply with quote  Mark this post and the followings unread
well one thing you can do is turn the LDR into a vactrol for more control.
you could use a simple LFO made with 2 opamps for square/triangle waves
and hook it up to it,. or maybe a simpe 4017 sequencer so you can create
more rhytmic effects. usually those boards have at least one resistor to
change the pitch which you could replace with a potentiometer or/and
another LDR/vactrol. But I have seen circuits before that only have a black
blob so maybe that's all you got. In that case or even if there is a resistor
you could also try powerstarving. just hook up a potentiometer in series with
the power input, this might create some interesting effects or it doesn't work
at all. good look and have fun exerimenting! Cool
http://www.acidtrash.com/
