FS: fonitronik VCPS-8 Sequencer, 19''/1U
Page 1 of 1 [2 Posts]
PostPosted: Sun Nov 20, 2011 8:49 am    Post subject: FS: fonitronik VCPS-8 Sequencer, 19''/1U
Subject description: Voltage Controlled Pattern Sequencer
I am selling the 1U /19'' rack-build of my Voltage Controlled Pattern Sequencer.
Since the PSU is laid out for european mains i would prefer selling in europe only. If someone wants to drive by and pick up the unit, i would be more than fine with it (no shipping/packaging trouble).
It is basically a 8-Step Sequencer with an ADC to control the steps. However, each step provides a 3-pos Slideswitch to set this particular step on, off, or ADC controlled.
All jacks are 3.5mm mini jack sockets. The frontpanel is a computer engraved from Schaeffer (there is a minor typo on it, that makes this unit even more special)
Here is the link to my project page:
http://www.modular.fonik.de/Page47.html
I am selling here the 19'', 3U unit, NOT the eurorack module.
This is a handbuilt single copy, so i ask for 300.-EUR.
I/O's and controlls:
Reset IN
Manual Reset
(the reset is set up to just reset on the rising edge, then the sequencer continues running - so no inhibit)
Clock IN
Manual Step
Pattern CV IN
Manual Pattern select (offset)
Fine offset
Pattern CV indicator LED's <0V>5V
8x 3-pos switch (Step On/Off/ADC)
8x CV Potentiometer
8x Pattern indicator LEDs
8x Step indicator LEDs
Trigger OUT (follows the incoming clock width)
Gate OUT
CV OUT
CV OUT Attenuator.
PostPosted: Thu Dec 15, 2011 12:05 am    Post subject: Reply with quote  Mark this post and the followings unread
Here's a short vid, i made:
