macumbista
Posted: Mon Nov 28, 2011 9:22 am Post subject:
Simple X-fader/Panning PCB project for DIY Serge Gator |
I've assembled almost everything I need to do a Serge Gator clone from the CGS collection, the one thing missing would be the X-fader/VC gain module.
I've looked at two projects out there, Fonik's X-Pan-Fade from the Triple Resonator module, and M. Bareille's SSM2164-based Quad VCA. The former may not be exactly what I am looking for (as well as unavailable), the latter is a bit large and expensive. Does anyone know a simple X-Fade or stereo panning project PCB that is approximately the same size format as the CGS modules? _________________ Esoteric drones and nonlinear distortion
macumbista.net |
ericcoleridge
Posted: Mon Nov 28, 2011 10:27 am Post subject:
Re: Simple X-fader/Panning PCB project for DIY Serge Gator |
I've been looking for solutions to the same problem--and I know of at least two other possibilities, the second one being the one I'm leaning towards (small enough to squeeze into a Serge style quad vca/panner):
Yu Synth VCpanner
Vactrol Panner
Also, here's a voltage controlled x-fader:
Bergfotron Crossfader
macumbista wrote: | I've assembled almost everything I need to do a Serge Gator clone from the CGS collection, the one thing missing would be the X-fader/VC gain module.
I've looked at two projects out there, Fonik's X-Pan-Fade from the Triple Resonator module, and M. Bareille's SSM2164-based Quad VCA. The former may not be exactly what I am looking for (as well as unavailable), the latter is a bit large and expensive. Does anyone know a simple X-Fade or stereo panning project PCB that is approximately the same size format as the CGS modules? |
richardc64
Audio files: 26
macumbista
Posted: Mon Nov 28, 2011 12:03 pm Post subject:
Oh that *is* elegant! Response is linear, isn't it? Maybe better for CV crossfade than for stereo audio output... _________________ Esoteric drones and nonlinear distortion
macumbista.net |
diablojoy
Joined: Sep 07, 2008 Posts: 809 Location: melbourne australia
Posted: Mon Nov 28, 2011 4:16 pm Post subject:
Haha thanks for the reminder i must post the schematic
as i said i would, my apologies , completely forgot about it . will try and get it posted before the weekend. _________________ In an infinite universe one might very well
ask where the hell am I
as good an answer as any |
ericcoleridge
Posted: Mon Nov 28, 2011 7:47 pm Post subject:
Yeah, this would be really nice for a lot of different applications. I'm always looking for a small parts count cross fader for all kinds of stuff. I'll have to try making a little layout for it. |
diablojoy
Posted: Mon Nov 28, 2011 9:27 pm Post subject:
Quote: | Yeah, this would be really nice for a lot of different applications. I'm always looking for a small parts count cross fader for all kinds of stuff. I'll have to try making a little layout for it. |
It does indeed look good
I think i could get 2 on a smallish board, would make a nice ancillary module might try and test out the lm13700 version
as long as it's ok with richardc64 ? _________________ In an infinite universe one might very well
richardc64
Audio files: 26
Posted: Mon Nov 28, 2011 10:18 pm Post subject:
Never seen my stuff called "elegant" before. I'll have to remember to keep a pinky raised whenever I post
Yeah, it's linear
diablojoy wrote: |
as long as it's ok with richardc64 ? |
Go for it. Might need a different current source than what my untested schema shows. _________________ Revenge is a dish best served with a fork... to the eye |
macumbista
Posted: Tue Nov 29, 2011 2:55 am Post subject:
diablojoy wrote: |
richardc64 wrote: |
Go for it. Might need a different current source than what my untested schema shows. |
If you work that one out, please let me know. I have a ton of dual OTAs sitting around. Can you explain why the LM13700 version needs a different current source than the 3080? Couldn't the op-amp buffer used in the single arrangement also be used in the dual? This part is a bit beyond my understanding... _________________ Esoteric drones and nonlinear distortion
macumbista.net |
richardc64
Audio files: 26
Posted: Tue Nov 29, 2011 9:04 am Post subject:
macumbista wrote: |
If you work that one out, please let me know. I have a ton of dual OTAs sitting around. Can you explain why the LM13700 version needs a different current source than the 3080? Couldn't the op-amp buffer used in the single arrangement also be used in the dual? This part is a bit beyond my understanding... |
Mine too, actually. But no, the op-amp and diode trick supplies the 3080 Iabc (the control current), AND -V. In the LM13700 -V is common to both OTAs, so this method can't be used. That's why I show the simple one-transistor current source in the untested '13700 version, but that might be too simple, and something better -- like a current mirror -- could be needed.
Someone more knowledgeable could perhaps offer some advice, if we could get that "someone's" attention. _________________ Revenge is a dish best served with a fork... to the eye |
emdot_ambient
Joined: Nov 22, 2009 Posts: 667 Location: Frederick, MD
macumbista
Posted: Tue Nov 29, 2011 1:53 pm Post subject:
richardc64 wrote: | the op-amp and diode trick supplies the 3080 Iabc (the control current), AND -V. In the LM13700 -V is common to both OTAs, so this method can't be used. |
That's interesting, since I was recently asking about the differences in OTAs in another thread. I was assured there wasn't much, now you're here to prove them wrong! _________________ Esoteric drones and nonlinear distortion
macumbista.net |
diablojoy
Posted: Tue Nov 29, 2011 4:13 pm Post subject:
Quote: | That's why I show the simple one-transistor current source in the untested '13700 version, but that might be too simple, and something better -- like a current mirror -- could be needed. |
seems I will need to do a bit more studying on this, always something more to learn i have quite a few of 3080 and lm13600/13700 but would rather keep the 3080's back for other ccts as the lm13700 are far more common
time will tell if i can figure it out.
Eric : seems i never actually drew up a proper schematic up for that vactrol pan on my computer so if i cant find the bit of paper i scrawled it on by the weekend i will have to backtrace the cct board though i think i remember most of it anyway.
oh well at least Its a very simple cct _________________ In an infinite universe one might very well
frijitz
Audio files: 54
Posted: Wed Nov 30, 2011 1:37 pm Post subject:
Hi all --
Richard asked me if I could comment on this discussion, especially re the OTAs.
First, this is really a brilliant design. I'm surprised it hasn't been pick up on before. I think lots of folks would be interested if boards were available. People seem to be getting more and more interested in modules with lots of features.
Comments on the original design: The reason for the oddball resistors around A4 is most likely that the left side of the 47k sees a finite impedance. If this point were buffered then the three odd resistors could all be 47k.
The unknown R below the Init control is there so the input CV (eg, envelope) can be burried below zero. I think it could actually be omitted, depending on how you like to use the CV In. IOW the Init pot can go across the +/- supply.
On the OTAs: When the 3080s were going away I suggested everybody stock up on them because of all the designs that use the Jung trick of driving through the power pin. I have a pretty good supply myself and I could probably let a few go for projects like this.
The question of whether the same drive configuration could be used on the 13600/13700 has been asked but AFAIK never resolved. Would it still work if only half the chip were used, or if the two halves were connected in parallel???
The untested current source would probably work, but I would prefer an active (opamp) summer approach. See the pt. 2 drawing here:
http://home.comcast.net/~ijfritz/Chaos/ch_cir6_chaotica.htm (lower left)
So at the cost of a dual opamp you could make the circuit a bit more precise. A matter of taste, for sure.
Ian Last edited by frijitz on Wed Nov 30, 2011 8:36 pm; edited 1 time in total |
richardc64
Audio files: 26
Posted: Wed Nov 30, 2011 7:03 pm Post subject:
Whoa! First "elegant", now "brilliant"...
Most brilliant, IMNSHO, is that it doesn't need switches to select the different functions. Less brilliant is that, since it uses just one OTA, it can't function as two normal VCAs, like the more common panning method.
frijitz wrote: | Comments on the original design: The reason for the oddball resistors around A4 is most likely that the left side of the 47k sees a finite impedance. If this point were buffered then the three odd resistors could all be 47k. |
Not sure what that means
Quote: | The unknown R below the Init control is there so the input CV (eg, envelope) can be burried below zero. I think it could actually be omitted, depending on how you like to use the CV In. IOW the Init pot can go across the +/- supply. |
I think I remember now; without the "unknown resistor" the init pot had to be rotated far off-center to make a single input come out at roughly equal levels on both outputs. Rather than figure out why that should be, I went for the expedient fix.
Quote: | The question of whether the same drive configuration could be used on the 13600/13700 has been asked but AFAIK never resolved. Would it still work if only half the chip were used, or if the two halves were connected in parallel??? |
THAT's something that might be worth exploring. Wish I had the facilities.
Quote: | The untested current source would probably work, but I would prefer an active (opamp) summer approach. See the pt. 2 drawing here:
So at the cost of a dual opamp you could make the circuit a bit more precise. A matter of taste, for sure. |
Yeah, that does look better. Besides being more precise it's simple enough to make trying to apply the Jung trick to the '13700 unnecessary.
Thanks so much for your insights! _________________ Revenge is a dish best served with a fork... to the eye |
frijitz
Audio files: 54
Posted: Wed Nov 30, 2011 9:33 pm Post subject:
richardc64 wrote: | Most brilliant, IMNSHO, is that it doesn't need switches to select the different functions. |
Exactly!
Quote: | frijitz wrote: | Comments on the original design: The reason for the oddball resistors around A4 is most likely that the left side of the 47k sees a finite impedance. If this point were buffered then the three odd resistors could all be 47k. |
Not sure what that means |
Hmmm... Let's try looking at it from a different angle. The outputs are not linear functions of the input pot settings, ie the gains of the two output amp circuits depends on the input pot settings. If you buffer the pot wipers, then the behavior is ideal. But maybe that's not the main issue here, especially if you do all the setup with the input pots full up or full down. So the needed R values might need a bit more explaining.
Quote: | I think I remember now; without the "unknown resistor" the init pot had to be rotated far off-center to make a single input come out at roughly equal levels on both outputs. Rather than figure out why that should be, I went for the expedient fix. |
That's odd. It was OK at the endpoints but not the middle?
Ian Last edited by frijitz on Thu Dec 01, 2011 11:43 am; edited 1 time in total |
macumbista
Posted: Thu Dec 01, 2011 7:44 am Post subject:
Hey Ian, thanks for checking in on this! I may just try prototyping this in the next week with your op-amp summer, I'll post back if I do. _________________ Esoteric drones and nonlinear distortion
macumbista.net |
richardc64
Audio files: 26
Posted: Thu Dec 01, 2011 9:27 am Post subject:
frijitz wrote: | richardc64 wrote: | I think I remember now; without the "unknown resistor" the init pot had to be rotated far off-center to make a single input come out at roughly equal levels on both outputs. Rather than figure out why that should be, I went for the expedient fix. |
That's odd. It was OK at the endpoints but not the middle? |
I should have written "...had to be rotated too far clockwise..." The unknown resistor allowed the 2 outputs to be equal when the init pot was centered. In other words, without the resistor the CV was "buried" over much, much more than half of the pot's rotation. _________________ Revenge is a dish best served with a fork... to the eye |
frijitz
Audio files: 54
Posted: Fri Dec 02, 2011 10:02 pm Post subject:
richardc64 wrote: | ...But no, the op-amp and diode trick supplies the 3080 Iabc (the control current), AND -V. In the LM13700 -V is common to both OTAs, so this method can't be used. |
So I finally tested the power-pin biasing on the LM13700. Using one half of the pair works exactly the same as the original. Using the two halves in parallel also works. I've started a new thread on the circuits.
http://home.comcast.net/~ijfritz/Chaos/ch_cir5_twc.htm
Ian |
diablojoy
Posted: Fri Dec 02, 2011 11:15 pm Post subject:
thanks Ian is really good of you to do that
will read the new thread with interest. _________________ In an infinite universe one might very well
macumbista
macumbista
Posted: Sun Dec 04, 2011 8:23 am Post subject:
Last question: the CV for this VCA would be bipolar, or positive only? _________________ Esoteric drones and nonlinear distortion
macumbista.net |
richardc64
Audio files: 26
Posted: Sun Dec 04, 2011 8:57 am Post subject:
macumbista wrote: | So in the second, you use which? Or does it depend which half of the OTA IC you are aiming at? |
Pin 1 or 16, depending on which half of '13700 is used.
Quote: | Last question: the CV for this VCA would be bipolar, or positive only? |
The original, with the Jung current source, was intended to function with either, with proper adjustment of the "initial" pot. As for Ian's method, I think I might've gotten in a bit over my head, here.
Maybe I should've kept quiet. _________________ Revenge is a dish best served with a fork... to the eye |
macumbista
Posted: Sun Dec 04, 2011 10:16 am Post subject:
Also, do you think there is any way this circuit to could overall voltage-controlled gain (like the Serge X-fader)? Maybe more CV summing tricks? Or another VCA needed? Hmmm.... _________________ Esoteric drones and nonlinear distortion
macumbista.net |
macumbista
Posted: Tue Dec 06, 2011 10:03 am Post subject:
This circuit shouldn't be any different with am LM13700, should it? See again my thread on differences between OTAs... _________________ Esoteric drones and nonlinear distortion
macumbista.net |
