MuBase
Posted: Sat Dec 03, 2011 12:51 pm Post subject:
matching...? Subject description: lm394 replace |
Hiya to the beautiful people of E-M! Im in the assembly stage of building an sn voice module (SMS audio PCB..Thanks Bill!! ) which i intend to put in an old coco commotion serial flowol box ( http://electro-music.com/forum/topic-50071.html ) and am 90 % done. Just waiting for the 2 x 1k smd tempcos from magicsmoke and a socket for the 76477.
I wish to ask though....
Is it alright to use 2 x 2n3904 s instead of an lm394? I was thinking i could make the legs smaller and fit them into the 8 pin dil . Then placing the serially soldered smd 1k tempcos over the transistors with epoxy...
Does anyone know if this would be ok and not trubblesome?
Please help!
Thankx.
Steve. _________________ There's a crack in everything...Thats how glue manufacturers make a living. |
Mongo1
MuBase
Posted: Sun Dec 04, 2011 5:41 am Post subject:
Matching.... Subject description: Thanks... |
Hi! Thanks for the reply. I will try this method today with the 2 2n3904s I have left from the 5 I ordered for the purpose of the SN voice. Something else to learn and add to my electronics knowledge repetoire!
Also I have just found a stockist in the UK of LM394's but not the DIP type. The can type. I assume these are good to use as long as you can fit the leads to the DIL socket??..
I will try the measurement method first though.
Thanks again!
Mongo1
Posted: Sun Dec 04, 2011 8:11 am Post subject:
| Quote: | | Also I have just found a stockist in the UK of LM394's but not the DIP type. The can type. I assume these are good to use as long as you can fit the leads to the DIL socket??. | .
Yes - they're the same.
Regarding the matching thing - Typically you'd want to have quite a few, and choose the ones with the best match. If you only have 5 you may not find a suitable pair.
The results you'll get with the LM394 will definitely be better - I'd snatch up one of those if I were you...
Good luck
Gary |
MuBase
Posted: Sun Dec 04, 2011 11:29 am Post subject:
Matching Wilco. |
OK Mongo, I get your drift...( no pun intended .) I did measure 2 simply just on a digital meter in the hFE socket and got 2 reading 175 and 179 but another reading 276?!?
Strange,
anyhow, I thought I'd have another try at finding the DIL type and found a Chinese Ebay source selling them for about $3.90 or something with $2.00 postage. It should take about 2-3 wks to get here but I think in the long run you are right. it will be worth it and it was relatively cheap! The cheapest deal I can find in the UK for DIL types is about £15.00 a pop!! Or I could get a canned version for £4.50 but the postage of £5.00 added would still make it more expensive than what I paid for the SN76477!!! Crazy.
Thanks again, will check in regularly with how the build is going. At the moment my main concern is with the layout on the box and how I will use the banana sockets to their best advantage...... :s
See Ya!! _________________ There's a crack in everything...Thats how glue manufacturers make a living. |
Danno Gee Ray
Joined: Sep 25, 2005 Posts: 1332 Location: Telford, PA USA
Posted: Sun Dec 04, 2011 6:49 pm Post subject:
| Go for the ones in the UK. |
adambee7
Joined: Apr 04, 2009 Posts: 420 Location: united kingdom
Posted: Mon Dec 05, 2011 2:02 pm Post subject:
http://vintageplanet.nl/ have dils at a good price. cricklewood electronics are 18 pounds now for lm394s.  |
MuBase
Posted: Mon Dec 05, 2011 4:46 pm Post subject:
The matching pair lies heavy... Subject description: Well... |
Hi! I did actually this morning order the DIL version from China before I read the new posts from you guys...( apparently they only take 2 weeks to the UK so that's not so bad and I am trying to keep a tighter budget what with being one of the Ranks of Unemployed at the moment ...:s . ) But, have I done the wrong thing? I have read reports about some ics from China being dodgy... _________________ There's a crack in everything...Thats how glue manufacturers make a living. |
Mongo1
Posted: Mon Dec 05, 2011 4:56 pm Post subject:
| Quote: | | have I done the wrong thing? I have read reports about some ics from China being dodgy.. | .
I think it's just highly variable.
I've actually had real good luck getting Caps and Resistor assortments from China. I haven't tried ICs though.
In the end, it will either work or it won't.
Gary |
MuBase
Posted: Tue Dec 06, 2011 5:15 am Post subject:
China chip. |
Hi Mongo. I think you're right. Highly variable. Anyhow we'll see... in the meantime I have just this minute recieved an SSM2044 through the post from UTsource ( another Chinese supplier of thousands of IC designs ) that I got for about £2.50! ( about $6.50.) I am planning on building a nice filter for SNv .Oh and thanks to "Magman." I managed to procure a 28pin SDIP socket from a 64pin having HACKsawed it down... . Great idea. Been having serious trouble sourcing an SDIP for the 76477 until now...see: http://electro-music.com/forum/topic-50758.html
The international joys of audio electronics.... _________________ There's a crack in everything...Thats how glue manufacturers make a living. |
adambee7
Posted: Tue Dec 06, 2011 3:22 pm Post subject:
UTsource are very good. very eager to please.  |
